3 Replies Latest reply on Jan 29, 2010 12:32 PM by Faser
    Resize effect maintaining the window centered
    Faser
      I have a TitleWindow that I open using the PopUpManager.
      PopUpManager.centerPopUp(paymentWindow);
      I would like to apply a resize effect when I show the window.
      <mx:Resize id="expand"  widthTo="640" heightTo="480"/>
      The problem is that the TitleWindow is resized from the upper left corner to the bottom right corner. So the popup is no more centered. How can I apply the same effect but maintaining the window centered in the screen while it is resized?
        • 1. Re: Resize effect maintaining the window centered
          Dazed&Flashed
          I don't understand completely.But below is a piece of code I wrote render a image as a zoom popup and then when i cliked on the pop up it resized to its original size. May be it can help you
          use :-
          img.addEventListener(MouseEvent.CLICK, image_click);
          img.addEventListener(ResizeEvent.RESIZE, image_resize);
          PopUpManager.addPopUp(img, this, true);
          and
          private function image_click(evt:MouseEvent):void {
                              PopUpManager.removePopUp(evt.currentTarget as Image);
          private function image_resize(evt:ResizeEvent):void {
                             PopUpManager.centerPopUp(evt.currentTarget as Image);
          If you are using image.
          • 2. Re: Resize effect maintaining the window centered
            Sophie_cordier
            Or you can use a composite effect, composed from a resize effect and a move effect. If you want to resize a window with x pixels on horizontal direction and y pixels on the vertical one:
            • create a resize effect with deltax = x/2 and deltay = y/2
            • create a move effect with deltax = -x/2 and deltay = -y/2
            Hope it helps.
            Sophie
            • 3. Re: Resize effect maintaining the window centered
              Faser Level 1
              Thank you I followed your suggestion in this way:
              var myPopup:PaymentDetails = PaymentDetails(PopUpManager.createPopUp(this,net.faser.PaymentDetails,true));
              myPopup.width=50;
              myPopup.height=50;
              PopUpManager.centerPopUp(myPopup);
              resizeEffect.widthTo = 640;
              resizeEffect.heightTo = 480;
              myPoint.x = myPopup.x;
              myPoint.y = myPopup.y;
              moveEffect.xTo = myPoint.x - 640/2;
              moveEffect.yTo = myPoint.y - 480/2;
              resizeAndMove.target = myPopup;
              resizeAndMove.play();
              <mx:Parallel id="resizeAndMove">
                  <mx:Resize id="resizeEffect" />
                  <mx:Move id="moveEffect" />
              </mx:Parallel>
