2 Replies Latest reply on Feb 1, 2010 7:18 AM by kc_chaitu
    XDPUtilsClientSide class could not be loaded
    kc_chaitu Level 2
      When I define an xfaForm variable to hold the process data in the workbench I get the following error:
      ----- Error Message -----
      Unexpected error encountered:
      The XDPUtilsClientSide class could not be loaded
      The schema will be ignored.
      If I cklick OK and check the form schema settings in the variable properties the schema is displayed.
      If I use the XPath Builder I cannot access the form fields. The path stops at /process_data/[VARIABLE_NAME]/object/data/xdp/datasets/data/FSFIELDS_
      I'm using LC 8.0 SP2 version.
      Anyone faced this issue?
      Chaitanya
