0 Replies Latest reply on Jan 29, 2010 9:48 AM by bobsc1
    Topic and TOC not opening TOC to linked topic
    bobsc1
      I have created an html help (web help) help file. I created the project manager folders then generated the TOC and modified it a bit. I mapped the topics to the application using text id as the map id. The links work fine from the application. I decided to change the TOC because I didn't like the groupings and wanted to make more ligical. After I moved them around, the TOC and the topic no longer synced to the TOC topic when the topic is called from the application. The TOC stays flat and doesn't open to show it. How do I keep the TOC synced with topic when calling the topic from the application? I am using RoboHelp 7 and mostly test with firefox 3.5.6 and MSIE 8.
      Thanks.
