0 Replies Latest reply on Jan 29, 2010 1:11 PM by Carol L. Frampton
    [svn:fx-4.0.0] 13895: TLF Build 595.
    Carol L. Frampton Level 2
      Revision: 13895
      Revision: 13895
      Author:   cframpto@adobe.com
      Date:     2010-01-29 13:11:01 -0800 (Fri, 29 Jan 2010)
      Log Message:
      TLF Build 595.
      Build 595
      • Fix 2537642 Bug, TLF Text: htmlText is not Rendered Correctly (importer issue with implied paragraphs)
      QE notes:
      Doc notes:
      Bugs:
      Reviewer:
      Tests run: checkintests
      Is noteworthy for integration:
      Modified Paths:
          flex/sdk/branches/4.0.0/frameworks/air-config.xml
          flex/sdk/branches/4.0.0/frameworks/flex-config.xml
          flex/sdk/branches/4.0.0/frameworks/libs/textLayout.swc
          flex/sdk/branches/4.0.0/frameworks/projects/textLayout/HowToUpgradeTLF.txt
          flex/sdk/branches/4.0.0/frameworks/projects/textLayout/ReleaseNotes.txt
          flex/sdk/branches/4.0.0/frameworks/projects/textLayout/src/flashx/textLayout/BuildInfo.as
          flex/sdk/branches/4.0.0/frameworks/projects/textLayout/src/flashx/textLayout/conversion/B aseTextLayoutImporter.as
          flex/sdk/branches/4.0.0/frameworks/projects/textLayout/src/flashx/textLayout/conversion/H tmlImporter.as
          flex/sdk/branches/4.0.0/frameworks/projects/textLayout/tlf.properties
      Added Paths:
          flex/sdk/branches/4.0.0/frameworks/rsls/textLayout_1.0.0.595.swf
      Removed Paths:
          flex/sdk/branches/4.0.0/frameworks/rsls/textLayout_1.0.0.594.swf
