1 Reply Latest reply on Sep 7, 2007 12:19 PM by kglad
    loading external jpegs
    jonnybennett Level 1
      I have a script that gets the names of images from a database. If the image name returned to flash is blank then the script says don't even try to load the jpeg. This all works fine. However if for example only 3 image names are returned as not blank it takes a lot longer to load those 3 images than it does if all 10 images are required to load?
      This might make sense if it was trying to load an image with a blank image name, however the script says if image name!='' then load the image.
      why would this be? it makes no sense.
