3 Replies Latest reply on Feb 9, 2010 8:02 PM by Balaji Sridhar
    RDS Server Configuration In Flash Builder
    Bliss_0
      Can someone please help me configure RDS Server In Flash Builder? I would greatly appreciate it
      sbliss
        • 1. Re: RDS Server Configuration In Flash Builder
          SunilAdobe Adobe Employee
          You can goto Window->preferences and type RDS and enter your RDS information there.
          Are you getting any errors?
          -Sunil
          • 2. Re: RDS Server Configuration In Flash Builder
            Bliss_0 Level 1
            Sunil
            Thanx for directing me to the RDS Server configuration dialog box. And no, no error message. I thought that the RDS server is installed with FB 4
            and that there will be step by step instruction somewhere in the help section to set it up. So, where will I find the needed information to populate RDS Server configuration dialog box? Please advise ASAP. Thanx.
            sbliss
            • 3. Re: RDS Server Configuration In Flash Builder
              Balaji Sridhar Level 2
              If you are using the new Data Centric RAD feature in Flash Builder, the RDS configuration should be taken care by itself.
              However, for a CF server your RDS information should look like this:
              Window->Preferences->RDS Configuration->New
              Description: RDSConfig
              Host Name: localhost(subject to where the server runs)
              Port No: 8501(actual port where server is running)
              Under Security information provide the RDS UserName and password given while installing the server and click 'Test Connection'.
              You should see a success message if all is well.
              For BlazeDS it should look like:
              Description: MyBlazeRDS
              Host Name: 8400
              Context Root: blazeds
              and click Test Connection.
              Hope it helps!
              Please mail me to balajs AT adobe DOT com in case you encounter any issues.
              Balaji
              http://balajisridhar.wordpress.com
