1 Reply Latest reply on Jan 30, 2010 1:03 PM by el_kolo
    Flex and javascript
    el_kolo
      I have a flex RichTextEditor and flex button. I want to copy to clipboard text from rich TextEditor to clipboard with rollOver the button. It is not possible to do this only with Action Script. Can I implement javascript "copy to clipboard function" which will copy this text after rollOver? Can do It with flex button or I have to create javascript button? Any tip will be helpful.
        • 1. Re: Flex and javascript
          el_kolo Level 1
          Ok i Have it. It works in IE but it is bettern then nothing:)
          Flex:
          private function jsSend():void{
              if (ExternalInterface.available){
                  s=richTextEditor.text;
                  ExternalInterface.call("copyT",s);
          <mx:Button rollOver="jsSend()"/>
          JavaScript:
          function copyT(s)
              if(window.clipboardData)
              window.clipboardData.setData('text',s);
              else
                  var clipboarddiv=document.getElementById('divclipboardswf');
              if(clipboarddiv==null)
                 clipboarddiv=document.createElement('div');
                     clipboarddiv.setAttribute("name", "divclipboardswf");
                 clipboarddiv.setAttribute("id", "divclipboardswf");
                 document.body.appendChild(clipboarddiv);
                  clipboarddiv.innerHTML='<embed src="clipboard.swf" FlashVars="clipboard='+
          encodeURIComponent(s)+'" width="0" height="0" type="application/x-shockwave-flash"></embed>';
              alert('The text is copied to your clipboard...');
              return false;
