16 Replies Latest reply on Feb 1, 2010 11:36 AM by Laubender
    New document a single page - not spread
    Michael L Hale Level 5
      I'm sure it's simple but I still can't get my head around the InDesign DOM. How can I create a new document without the pages being in a spread?
      Here is what I have now
           function addDocument ( w, h ){
                var myDocument = app.documents.add();
                myDocument.viewPreferences.horizontalMeasurementUnits = MeasurementUnits.points;
                myDocument.viewPreferences.verticalMeasurementUnits = MeasurementUnits.points;
                myDocument.viewPreferences.rulerOrigin = RulerOrigin.pageOrigin;
                myDocument.documentPreferences.pageWidth = w;
                myDocument.documentPreferences.pageHeight = h;
                // want only one page 'spread' and set the margins
                var myMasterSpread = myDocument.masterSpreads.item(0);
                var myMarginPreferences = myMasterSpread.pages.item(0).marginPreferences;
                myMarginPreferences.left = 0;
                myMarginPreferences.top = 0;
                myMarginPreferences.right = 0;
                myMarginPreferences.bottom = 0;
                myMarginPreferences.columnCount = 1;
                myMarginPreferences.columnGutter = 0;
                myDocument.pages[0].appliedMaster = myMasterSpread;
                return myDocument;
        • 1. Re: New document a single page - not spread
          Peter Kahrel Adobe Community Professional & MVP
          Michael,
          That's how I feel about the PhotoShop DOM. You'd think that if you're familiar how one works you should be able to come to grips with another, but that's not my experience. PS is still a struggle.
          But anyway, the problem you describe is known. You'd think that setting facing pages to false would do the trick:
          myDocument.documentPreferences.facingPages = false;
          but it doesn't. I've seen an elaborate fix a while ago in a Swiss forum but I can't remember that. When I need a one-page master spread I simply delete a page. After your line
          insert this one:
          myMasterSpread.pages.item(0).remove ();
          Must be page 0, not 1, because page 1 is applied to document page 1. You'd think that
          Then you end up with an inelegant one-page master spread with facing pages enabled, so you could still disable that.
          Peter
          • 2. Re: New document a single page - not spread
            Thanks that did the trick. The next time you have trouble with Photoshop give me a shout in the Photoshop Scripting forum or at PS-Scripts and I will try help.
            • 4. Re: New document a single page - not spread
              Muppet Mark Level 5
              Peter, mikes code worked first time for me because the last newly created doc before the script created doc did not have facing pages. So I think the page removal should be in if statement.
              if (myMasterSpread.pages.length == 2) myMasterSpread.pages.item(0).remove ();
              else I some times get 'A document must have at least one page.'
              • 5. Re: New document a single page - not spread
                @Peter:
                I think you mean the following thread:
                http://www.hilfdirselbst.ch/gforum/gforum.cgi?post=405554#405554
                In essence Hans Haesler pointed out, that it might be a good idea to use the standard document preferences:
                app.documents.add(true, app.documentPresets[0]);
                Uwe
                • 6. Re: New document a single page - not spread
                  Mark --
                  Yes, true.
                  P.
                  • 7. Re: New document a single page - not spread
                    Thanks, Uwe, that's the one
                    Peter
                    • 8. Re: New document a single page - not spread
                      Steven.. Level 3
                      Facing pages can only be set before document is created. Changing the app preference is the way to go
                           app.documentPreferences.facingPages = false;
                           addDocument (100, 600);
                                return myDocument;
                      This is like changing the preference in dialog when creating new document
                      • 9. Re: New document a single page - not spread
                        Aha! Thanks, Steven.
                        • 10. Re: New document a single page - not spread
                          Steven.. Level 3
                          if developing for third party resetting preference is suggested
                          var bFacingPages = app.documentPreferences.facingPages;
                          if (bFacingPages) app.documentPreferences.facingPages = false;
                          addDocument(100,600);
                          if (bFacingPages) app.documentPreferences.facingPages = true;
                          Otherwise the next time user opens New document dialog, they might not realize that you have changed preference of app.
                          • 11. Re: New document a single page - not spread
                            Stephan,
                            sorry to say, but your suggestion is not working for me (InDesign CS4 6.0.4 German Version on Mac OS X 10.5.8).
                            Instead of generating a single page document above code uses part of the previous used document preference file.
                            What I am doing wrong?
                            See also the screen shots:
                            //NewDoc_SinglePages_SingleMasterSpreadPage.jsx
                            //31.01.2010
                            //DOES NOT WORK AS EXPECTED:
                            //1.No single page in MasterSpread[0]
                            //2.No single page file
                            //3.Therefore: marginPreferences, columnCount and columnGutter only for left pages as expected
                            //AS EXPECTED:
                            //1.Number of pages generated as stated in previous used documentPreferences setting
                            //Suggestion by Peter Kahrel:
                            //http://www.hilfdirselbst.ch/gforum/gforum.cgi?post=432223#432223
                            //Triggered by Stephan:
                            //http://forums.adobe.com/message/2556914#2556914
                            // record current state
                            var state = app.documentPreferences.facingPages == true;
                            //Function call for an A4 sized document:
                            myDoc = addDocSinglePageWidthHeight(210,297);
                            // restore state
                            app.documentPreferences.facingPages = state;
                            //Function by: Michael L. Haile
                            //http://forums.adobe.com/message/2556113#2556113
                            //~ function addDocument ( w, h ){
                            //Edited by Uwe Laubender:
                            //function name
                            //MeasurementUnits=Millimeters
                            function addDocSinglePageWidthHeight ( w, h ){
                                      myDocument.viewPreferences.horizontalMeasurementUnits = MeasurementUnits.MILLIMETERS;
                                      myDocument.viewPreferences.verticalMeasurementUnits = MeasurementUnits.MILLIMETERS;
                                      return myDocument;
                            The following code does what I want:
                            app.activeDocument.documentPreferences.pageWidth="100mm";
                            app.activeDocument.documentPreferences.pageHeight="200mm";
                            It generates a single sided document with a single page master spread, 100 x 200 mm.
                            Uwe
                            • 12. Re: New document a single page - not spread
                              Uwe,
                              Try this:
                              myDoc = app.documents.add ();
                              // restore state
                              // now continue with myDoc
                              myDoc.marginPreferences etc
                              • 13. Re: New document a single page - not spread
                                Thank you, Peter.
                                But:
                                //Code2:
                                // restore state
                                myDoc.documentPreferences.pageWidth = "150mm";
                                myDoc.documentPreferences.pageHeight = "300mm";
                                yields nothing new:
                                If I put in another line for facingPages set to false:
                                //Code 3:
                                // restore state
                                myDoc.documentPreferences.facingPages = false;
                                I'll get the following doc:
                                which is not the thing I want, because masterSpreads.item(0) still consists of two pages…
                                So it seems that
                                in front of
                                does nothing at all.
                                I use a German version of InDesign CS4 6.0.4 on a German Mac OS X 10.5.8. Maybe that's the point.
                                Uwe
                                • 14. Re: New document a single page - not spread
                                  Steven.. Level 3
                                  Something is interesting here. Your code created document with 1 page master on my computer. Even in your pictures you have 1 page spreads but with 2 page master ????
                                  To see if app.documentPreferences.facingPages = false; works, close all documents and check File->DocumentSetup Menu Dialog (Translated to German) the setting of facing pages should be toggled with that code.
                                  documents.add() is like pressing Ctrl+Alt+N where document with default setting are created.
                                  All we are doing in code is changing default setting and then creating default document.
                                  Try doing in the UI and checking if the result is the same.
                                  It would be weird for it to change based on version German etc.. since that only seems to affect strings displayed, However German does seem to be different as I have experienced problems that just showed up on German version.
                                  • 15. Re: New document a single page - not spread
                                    Hi Steven,
                                    I checked the default document preferences in UI (no document is open). "Facing pages" is off. See screen shot:
                                    With "app.documentPreferences.facingPages = true;" I can change that to "Facing pages: on".
                                    "app.documentPreferences.facingPages = false;" will bring it back to "Facing pages: off".
                                    However, when I do "app.document.add()" or do it's equivalent in UI, InDesign takes the last used document preset to construct a new document.
                                    If the last used document preset happens to be one with option "Facing pages: on", the new doc will logically obtain all properties not included in the script. Therefore an "app.document.add()" only will yield in a document with all properties defined according to the last used document preset.
                                    To change this you can either:
                                    use a different document preset like the default preset "app.document.add(true, app.documentPresets[0])" which happens to be a single pages document by default with a master spread definition of one single page
                                    or try to give all the needed properties and remove master page number two :
                                    var myDoc = app.documents.add();
                                    with(myDoc.documentPreferences){
                                         pageHeight = "250mm";
                                         pagesPerDocument = 5;
                                    with(myDoc.viewPreferences){
                                         rulerOrigin = RulerOrigin.PAGE_ORIGIN;
                                    with(myDoc.masterSpreads.item(0).pages.item(0).marginPreferences){
                                         top = "0mm";
                                         left = "0mm";
                                         right = "20mm";
                                         bottom = "0mm";
                                         columnCount = 1;
                                    //I know there might be a "myDoc.masterSpreads.item(1)", but it will never be applied to the doc pages
                                    //Therefore I can delete it. Cautiously I will put that in an if statement:
                                    if(myDoc.masterSpreads.item(0).pages.length>1){
                                            myDoc.masterSpreads.item(0).pages.item(1).remove();
                                    With that approach in the beginning my master spread will always contain two pages. I cannot see the possibility to define my master spread to one page only in advance.
                                    Now I tried to implement your suggestion with "app.documentPreferences.facingPages = false;" in front of the code, but it does not influence the construction of the master spread.
                                    One word about "app.documentPresets[0]": I found that it's default after a fresh install of InDesign is "Facing pages: off". However you can edit this later to "Facing pages: on", so my bet is to stay with the solution working only with "app.document.add()", add all necessary properties and remove the needless master page when building single sided documents.
                                    Uwe
                                    • 16. Re: New document a single page - not spread
                                      Follow up:
                                      Now I'm sure that the German version of InDesign behaves different to the American version. I just checked that with a friend in Egypt who is working with an American version of InDesign CS4 6.0.4.
                                      Uwe
