7 Replies Latest reply on Feb 5, 2010 9:40 PM by Jane Smith 2300
    How to detach CSS for just one page
    Jane Smith 2300 Level 1
      I am planning to redesign my site which has CSS styles, including CSS style for the background picture.
      I would like to see how my site would look with a different background but keep all of the typographical styles, etc. that I have made. If I delete that one style element from the CSS styles sheets then it will impact all the other pages in my site--I don't want this to happen. So what do I do?
      Can you delete just one feature of CSS styles for just one page?
      Or, should I copy the CSS styles into another stylesheet, delete the background style and attach that to my new page so I can see what it looks like?
      Thanks for any help.
      Jane
        • 1. Re: How to detach CSS for just one page
          Don't delete rules.  Instead use embedded or inline CSS on that page only.
          Inline CSS - mostly used for HTML emails.  Inline styles appear inside the HTML code and take priority over other embedded or external styles.
          <body style="background: url(new-BG.jpg) repeat">
          your page content
          </body>
          Embedded CSS - used on single pages. Appears between the <head> and </head> tags of your HTML page. Embedded styles take priority over external styles.
          <style type="text/css">
          body {
          background: url(new-BG.jpg) repeat;
          </style>
          External CSS - global site styles inside a separate physical file to which html pages are linked.
          Nancy O.
          Alt-Web Design & Publishing
          Web | Graphics | Print | Media  Specialists
          www.alt-web.com/
          www.twitter.com/altweb
          www.alt-web.blogspot.co
          • 2. Re: How to detach CSS for just one page
            Thank you for answering my question.(see below).
            Would you mind telling me what the code should be, in the example below, if I just want the background to be white for that one page?
            Jane
            your page content
            </body>
            body {
            </style>
            • 3. Re: How to detach CSS for just one page
              In that case, create an ID in your external stylesheet like so:
              #plain-BG
              {background-color: #FFF;
              background-image:none;
              HTML:
              <body id="plain-BG">
              Your page content goes inside the body tags.
              </body>
              Nancy O.
              www.alt-web.com/
              www.alt-web.blogspot.com
              • 4. Re: How to detach CSS for just one page
                Thank you, Nancy. Your answer was right on.
                Jane
                • 5. Re: How to detach CSS for just one page
                  Hi Nancy,
                  I thought I understood your reply (see below) but there is one thing I guess I didn't get:
                  #plain-BG
                  HTML:
                  </body>
                  My question is about the HTML code you suggested above: After making an ID I went to the HTML code and tried to enter the 3 lines you suggestsed. But I kept getting errors. All the rest of my page content disappeared.
                  </body>
                  I don't know where to put this. In the head? body?  If it's the body, do I just copy the entire 3 lines and put it in the body?? I tried that and it didn't work. Am I doing something incorrect?
                  I guess it's really the first line   <body id="plain-BG">  that I don't understand.
                  If you can help with this I would be most appreciative.
                  Jane
                  • 6. Re: How to detach CSS for just one page
                    No.  Only one <body> tag is allowed per page.  Copy and paste this code into a new, blank HTML document.
                    <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
                    <html xmlns="http://www.w3.org/1999/xhtml">
                    <head>
                    <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
                    <title>Plain Background</title>
                    #plain-BG {
                    </style>
                    </head>
                    <h1>H1 Heading</h1>
                    <p>Lorem ipsum dolor sit amet, consectetur adipiscing elit. Donec lorem diam, lacinia
                    vel cursus ut, accumsan sed sapien. Proin ipsum enim, fringilla at semper eu,
                    feugiat vel arcu? Cras a tortor ac mauris pharetra dictum nec et odio! Morbi
                    gravida magna sed urna fermentum sed ornare sapien interdum. Nunc eu lorem purus.
                    Phasellus posuere condimentum magna in malesuada. Ut fermentum ultrices quam
                    sed iaculis. Aenean at lacinia urna? Suspendisse potenti. Curabitur egestas dignissim
                    tortor vel mattis? Sed sed semper lectus. Class aptent taciti sociosqu ad litora
                    torquent per conubia nostra, per inceptos himenaeos.</p>
                    </body>
                    </html>
                    Nancy O.
                    www.alt-web.com/
                    • 7. Re: How to detach CSS for just one page
                      Hi Nancy,
                      This will be the final email on this topic.
                      You have completely answered my question.
                      Thank you so much for answering my question.
                      I didn't know that the opening body tag could be changed to:
                      Your solution worked perfectly.
                      Thanks again.
                      Jane
