3 Replies Latest reply on Feb 1, 2010 9:20 AM by Ned Murphy
    Clock hand rotation issue?
    DigiFront
      Hey there!
      I have some code that I have pulled from various sources and thought it was straight forward... but it seems to have a simple issue. As the hand rotates around with the script, but it gets to 180 degrees and then resets itself into the "-" value?... to times down from -180 to 0.... I need the time to run as a 10min timer?....
      Any suggestions!?
      Main:
      stop();
      _root.stopBtn._visible = false;
      _root.stopTxt._visible = false;
      myTimer = setInterval(play, 1000);
      function wait() {
          mySeconds++;
          _root.mySecondHand._rotation += 1;
          _root.myMinuteHand._rotation += 30;
          _root.myMilliSeconds._rotation += 1;
          if (mySecondHand._rotation == 3600) {
              _root.clearInterval(myTimer);
      Button:
      on (release) {
          myTimer = setInterval(wait, 101);
        • 1. Re: Clock hand rotation issue?
          You could use a variable to keep track of the growing rotation value rather than the _rotation value itself.  Each time you change the _rotation, you change that variable by the same amont, and use that variable for your conditional test rather than the actual rotation value.
          stop();
          var secondCount = 0;
          function wait() {
              mySeconds++;
               secondCount += 1;
              _root.myMinuteHand._rotation += 30; // one fast minute hand
              _root.myMilliSeconds._rotation += 1; // one slow msec hand
              if (secondCount == 3600) {
          Button:
          on (release) {
          • 2. Re: Clock hand rotation issue?
            DigiFront Level 1
            Thanks Ned!
            Thats working nicely
            • 3. Re: Clock hand rotation issue?
              You're welcome
