6 Replies Latest reply on Feb 1, 2010 3:07 PM by John Hall
    Tabnavigator selectedIndex issue
    John Hall Level 4
      I have a TabNavigator. The script controlling portion of it is:
                  private function init():void{
                      tabNavBar.selectedIndex = 2;
      this works fine as the third tab is selected upon creationComplete of the component.
      However, if I send in an int via scripting, nothing changes.
                  public function changeTab( e:FormEvent ):void {
                      Alert.show("Event value passed in is " + e.tabIndex.toString());           // Alerts Event value passed in is 0
                      Alert.show("Starting value is " + tabNavBar.selectedIndex.toString());  // Alerts starting value is -1 (no children??)
                      tabNavBar.selectedIndex = e.tabIndex;
                      Alert.show("Tab is now" + tabNavBar.selectedIndex.toString());          // Alerts Tab is now 0 (correct but doesn't change)
      Things I've tried:
      validateNow();
      int(e.tabIndex)
      e.tabIndex as int;
      Other suggestions?
      Thanks.
        • 1. Re: Tabnavigator selectedIndex issue
          David_F57 Level 5
          the following code changes the tabnavigator programmatically, when you press the tabbar the change event then sets the tabnavigator to match . When you set the selected index it should just work, are you doing this from a popup window as that may have an effect on how the component updates(note: I'm using the latest sdk).
          you could try setting the update flag(this shouldn't really have any effect), tabnav.updateCompletePendingFlag=true; but without the full code its hard to say what the problem is.
             xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600"
             creationComplete="application1_creationCompleteHandler(event)">
          <fx:Script>
          <![CDATA[
          import mx.collections.ArrayCollection;
          import mx.events.FlexEvent;
          import spark.events.IndexChangeEvent;
          [Bindable] private var myArr:ArrayCollection = new ArrayCollection(['1','2','3']);
          protected function application1_creationCompleteHandler(event:FlexEvent):void
          tabnav.selectedIndex = 1;
          protected function buttonbar1_changeHandler(event:IndexChangeEvent):void
          tabnav.selectedIndex = event.newIndex;
          </fx:Script>
          <fx:Declarations>
          <!-- Place non-visual elements (e.g., services, value objects) here -->
          </fx:Declarations>
          <mx:TabNavigator id="tabnav" x="174" y="191" width="579" height="254">
          <s:NavigatorContent label="Tab 1" width="100%" height="100%">
          </s:NavigatorContent>
          <s:NavigatorContent label="Tab 2" width="100%" height="100%">
          <s:NavigatorContent label="Tab 3" width="100%" height="100%">
          </mx:TabNavigator>
          <s:ButtonBar x="204" y="78" dataProvider="{myArr}" change="buttonbar1_changeHandler(event)"/>
          </s:Application>
          • 2. Re: Tabnavigator selectedIndex issue
            John Hall Level 4
            If I put a button near the tab navigator and control it there it's fine. It's solely when the index is passed in as an event property, which is pretty strange. I'll see if I can make a pared down repro but it's one of those awful things where you're 40 files into a project in the nightly builds and this little thing pops up. Creating a repro almost entails creating a new app since I'm also using the Mate framework. ARgh.
            • 3. Re: Tabnavigator selectedIndex issue
              John Hall Level 4
              OK. Created a little repro if anyone has time to take a look. This zip file is an export out of FlashBuilder so you should be able to import directly.
              Since it does seem to make a difference these days, I'm using build 13654 on this right now.  In fact, with the latest build the test file couldn't find sparkSkins and I wasn't patient enough to debug for a repro case.
              Thanks for any insights.
              • 4. Re: Tabnavigator selectedIndex issue
                Flex harUI Adobe Employee
                Mate is creating a new instance of the TabNavigator in order to handle the
                FormEvent.
                • 5. Re: Tabnavigator selectedIndex issue
                  John Hall Level 4
                  What a great clue. That's a programming error on my part then. Thanks!! I could have scratched my head for a while.
                  • 6. Re: Tabnavigator selectedIndex issue
                    John Hall Level 4
                    One line of code and it's all fixed. Thanks so much as usual.
