1 Reply Latest reply on Feb 2, 2010 3:33 AM by RoboColum(n)
    display of robohelp file in application
    mrobo
      I have created a robohelp 8.02 html project.
      When I display the project in the application that is displayed in IE 7,  the table of contents is shifted to the right and can cut off words in the table of contents when the file name for the topic is to long.  It moves everything to the right.  If you expand the pane to cover the longest topic title, there is no shifting to the right.
      Is this a normal behavior?
      If this is not the normal behavior, can you please tell me how to fix this.
      Thanks.
        • 1. Re: display of robohelp file in application
          RoboColum(n) Level 5
          Do you mean that the width of the TOC is too narrow meaning that the title of books and topics is cut off? If so, this is standard behaviour but if you hover the mouse over a book/topic a tooltip gives the full name. Depending on your output type you may be able to change the default TOC pane width.
          • Read the RoboColum(n) for a tips, tricks and musings on the Technical Communication Suite products.
          • Follow the RoboColum(n) on Twitter
