3 Replies Latest reply on Feb 2, 2010 9:49 PM by jake_flex
    Problems in Flex Ant
    skolman83
      Here is the Build file I am using:
      <?xml version="1.0" encoding="UTF-8" standalone="no"?>
      <project basedir="." default="build" name="Project_name">
      <property environment="env"/>
      <property name="FLEX_HOME" value="C:/Program Files/Flex 3.4"/>
      <property name="APP_ROOT" value="./src"/>
      <property name="Project_name.location" value="../Project_name"/>
      <taskdef resource="flexTasks.tasks" classpath="${FLEX_HOME}/ant/lib/flexTasks.jar"/>
      <target name="build">
      <mxmlc file="${APP_ROOT}/AdminConsole.mxml">
      <source-path path-element="${FLEX_HOME}/frameworks"/>
      <library-path>
      <path-element>${Project_name.location}/src</path-element>
      </library-path>
      </mxmlc>
      </target>
      </project>
      I have a flex library I want to use located in another flex project in eclipse. So I am using the library-path element but when I run the build.xml file, this is the error i get:
      BUILD FAILED
      *************\build.xml:9: library-path doesn't support the nested "path-element" element.
      I tried it as an attribute for library-path but I still get a similar error:
      *************\build.xml:9: library-path doesn't support the "path-element" attribute
      What am I doing wrong?
        • 1. Re: Problems in Flex Ant
          jake_flex Level 2
          You should use compiler.library-path to include libraries.
          Try the following
           <compiler.library-path>
           <include name="${Project_name.location}/src" />
           </compiler.library-path>
           </mxmlc>
          </target>
          </project>
          Although, I don't know what are you planning to include, and whether you should use compiler.library-path for that.
          • 2. Re: Problems in Flex Ant
            skolman83 Level 1
            Thanks, that worked!
            how about for external-library-path? I tried
            <compiler.external-library-path
            path-element="${project_name.location}/bin/project_name.swc"/>
            But it gave this error:
            compiler.external-library-path doesn't support the "path-element" attribute
            and this is all documented anywhere?
            • 3. Re: Problems in Flex Ant
              jake_flex Level 2
              I haven't used external library-path ever. Can't you use the same compiler.library-path tag? Just add another nested include tag.
              The documentation is really poor on the Flex Ant Tasks. The only one I know is
              http://livedocs.adobe.com/flex/3/html/help.html?content=anttasks_1.html
              which is not very descriptive and does not cover all the options available.
