3 Replies Latest reply on Feb 2, 2010 6:05 PM by Harry Kunz
    Flash layers - On a map
    A.Boother
      Hi All,
      I've created a map that can be found here: http://www.bletsoes.co.uk/content.php?p_department=RS&page=sales
      The problem is that the layers are just not right. When you try to hover over the top area, if you hover over it to the left or right it highlights the left or right area rather than the area your cursor is on. This is obviously because each layer is overlapping even though the image of each slice isnt, but I'm not sure how to correct this. I hope I've explained the problem clear enough! I've attached the flash file so you can see the code.
      Regards.
      Adam
