12 Replies Latest reply on Feb 2, 2010 7:04 PM by miguel8312
    Progress bar does not update help
    miguel8312 Level 3
      public
      var record:Array = new Array();
      var Sub:String = new String();               Sub ==
      "Y";
      var obj:Object;
      var obj2:Object;
      var result:String = new String(fr.data);
                     record = result.split(
      "\r\n");// carriage return begin new line
      //trace(result);
      for ( var i:int = 0; i<record.length; i++)// ++ stands for increment
                     obj =
      new Object();               fields = record[i].split(
      ",");// separate each field by comma.
                     count=count+1;
                     obj.col1 = fields[0];
                     obj.col2 = fields[1];
                     obj.col3 = fields[2];
      /// fields is an array that grabs the information from the position given
                     obj.col4 = fields[3];
      /// then we push the field into the objext and then the object into the record
                     obj.col5 = fields[4];
      /// then bind to datagrid.
                     obj.col6 = fields[5];
                     obj.col7 = fields[6];
                     obj.col8 = fields[7];
                     obj.col9 = fields[8];
                     obj.col10 = fields[9];
                     obj.col11 = fields[10];
                     obj.col12 = fields[11];
                     obj.col13 = i+1;
                     pbProgress.setProgress( (count % 10), 100 );
      trace(pbProgress.setProgress( (count % 10), 100 ));
       function eventComplete(event:Event):void{
      here is my code  i have a progress bar that does not show the 100% until i completed loaded the array into the datagrid what i would like to do is show a percentage everytime the it loops through the array can anyone point me in the right direction.
      Miguel
        • 1. Re: Progress bar does not update help
          miguel8312 Level 3
          public
                         Sub ==
          "Y";
          var obj:Object;
          var obj2:Object;
          var result:String = new String(fr.data);               record = result.split(
          //trace(result);
                         obj =
          new Object();
                         count=count+1;
                         obj.col13 = i+1;
          • 2. Re: Progress bar does not update help
            miguel8312 Level 3
            bump any ideas?
            • 3. Re: Progress bar does not update help
              Peter deHaan Level 4
              Did you set the ProgressBar control's mode to "manual"?
              Peter
              • 4. Re: Progress bar does not update help
                miguel8312 Level 3
                <mx:ProgressBar
                visible="{fr != null}"
                mode="manual"
                label=""
                id="pbProgress"
                labelPlacement="center"
                 width="162"/>
                here is my progress bar it is set to manual i like for it to update everytime it loops but it does not. The only time it updates is when it finished loading the datagrid.
                Is rather frustuating.
                • 5. Re: Progress bar does not update help
                  I tested with your ProgressBar code and a Timer and it seemed to work as expected in Flex 3.5:
                  <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" initialize="init();">
                      <mx:Script>
                          <![CDATA[
                              import mx.controls.Alert;
                              private const MAX:uint = 10;
                              private var count:uint = 0;
                              private var tmr:Timer = new Timer(1000, 11);
                              private function init():void {
                                  tmr.addEventListener(TimerEvent.TIMER, tmr_timer);
                                  tmr.addEventListener(TimerEvent.TIMER_COMPLETE, tmr_complete);
                                  tmr.start();
                              private function tmr_timer(evt:TimerEvent):void {
                                  pbProgress.setProgress(count, MAX);
                                  count++;
                              private function tmr_complete(evt:TimerEvent):void {
                                  Alert.show(evt.type);
                      </mx:Script>
                      <mx:Label id="sdkVer" initialize="sdkVer.text = mx_internal::VERSION;" selectable="true" />
                      <mx:ProgressBar id="pbProgress"
                                      mode="manual"
                                      label=""
                                      width="162"/>
                  </mx:Application>
                  Peter
                  • 6. Re: Progress bar does not update help
                    miguel8312 Level 3
                    thank you Pete but how do i incorporate in a loop ? if i seen examples similar to this in the past but never with a loop?... Thanks for all your help thus far.
                    • 7. Re: Progress bar does not update help
                      Well, what are you trying to show the progress of? How far the user has scrolled down a DataGrid? The % loaded of an external file? I'm unclear on when your event handler gets called which is updating the ProgressBar.
                      Peter
                      • 8. Re: Progress bar does not update help
                        miguel8312 Level 3
                        <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute">
                        <mx:Script>
                             <![CDATA[
                                  private function init():void{
                                  var i:int;
                                  for (i = 0; i < 50; i++)
                                      trace(i);
                                  pbProgress.setProgress(i, 50);
                                       var delayTimer:Timer;
                                       delayTimer = new Timer(10000, 100 );
                                       delayTimer.start();
                        </mx:Script>
                        <mx:ProgressBar
                                  mode="manual"
                                  label=""
                                  id="pbProgress"
                                  width="162"/>
                        <mx:Button click="init()" x="75" y="49"/>
                        </mx:Application>
                        in my application the user clicks a browser button which i then call filereference to loop through a csv file that then gets parsed and inputted into a datagrid. what i would like to do is to put a progress bar to gauge how  far along is the loop, because the application goes blank for a few seconds or minutes depending on the loop. I have taken the example to a much simplistic level like the code above I guess im not allow to use the progressbar in this fashion?.... sorry if i sound like an idiot im just a flex noob .
                        thanks
                        Miguel
                        • 9. Re: Progress bar does not update help
                          The problem with your example above is that the for loop will execute very quickly so you probably will just see the ProgressBar jump straight to 100% complete. Also, the Timer wont really do, well, anything since you arent listening for a timer or timerComplete event.
                          How about modifying your original example to use this code instead in the for loop:
                          pbProgress.setProgress( i, record.length );
                          Peter
                          • 10. Re: Progress bar does not update help
                            miguel8312 Level 3
                            thanks for all your help pete i guess this is not doable  with a loop. I guess the progress bar was just not meant to be used in this fashion. I'll have to rethink what to do until the datagrid is full with data.
                            Miguel
                            • 11. Re: Progress bar does not update help
                              I'm certain that it is quite do-able, I'm just using various timers to simulate having actual data...
                              The following example uses a timer to add a new record to a DataGrid control every 100ms. Then whenever the code adds a new record to the ArrayCollection (which is bound to the DataGrid control's data provider), I update the ProgressBar accordingly. After all 200 records have been added to the data provider (takes around 20 seconds), I hide the ProgressBar.
                              I'm just wondering if maybe you're setting the progress bar with an incorrect current/total value).
                                  <mx:Script>
                                      <![CDATA[
                                          private var timer:Timer = new Timer(100 /* ms */,
        200 /* iterations */);
                                              timer.addEventListener(TimerEvent.TIMER, timer_timer);
                                              timer.addEventListener(TimerEvent.TIMER_COMPLETE, timer_timerComplete);
                                              timer.start();
                                          private function timer_timer(evt:TimerEvent):void {
                                              var obj:Object = {c1:'Column 1', c2:'Row ' + timer.currentCount};
                                              arrColl.addItem(obj);
                                              pbProgress.setProgress(timer.currentCount, timer.repeatCount);
                                          private function timer_timerComplete(evt:TimerEvent):void {
                                              pbProgress.visible = false;
                                              pbProgress.includeInLayout = false;
                                  </mx:Script>
                                  <mx:ArrayCollection id="arrColl" />
                                  <mx:Panel>
                                      <mx:DataGrid id="dg" dataProvider="{arrColl}" width="300" />
                                      <mx:ControlBar>
                                          <mx:ProgressBar id="pbProgress" mode="manual" label="%1 of %2 records added (%3%%)" labelPlacement="center" width="100%" height="40" />
                                      </mx:ControlBar>
                                  </mx:Panel>
                              </mx:Application>
                              • 12. Re: Progress bar does not update help
                                miguel8312 Level 3
                                I dont think im using the incorrect parameters on the  processbar but i guess I might be. I mean here it is.
                                pbProgress.setProgress(i,record.length);
                                this is like you suggested earlier. i think is a question of where do i need to have this? im looping throught a bytearray and then push the arrary to the datagrid... i think your example is closer to what i need yet im struggling on making it fit to my needs. however im very greatful for all  your help. In VB I've been able to do this very simple but i guess my ignorance in flex is making my life a little harder :-) thanks for all your help pete.
                                Miguel
