4 Replies Latest reply on Feb 2, 2010 5:42 PM by vu.tuan.anh
    StackOverFlowError when task is assigned to user
    vu.tuan.anh
      Hi all,
      I have java.lang.StackOverflowError when task is assigned to user.in the workflow:
      User A escalate task to User B.
      In between there are several JDBC call and set value operation.
      When the step Assign to User B is created (User Task), I have java.lang.StackOverflowError. Below is the exception from adminui > stalled operation:
      nested exception is: java.lang.StackOverflowError: com.ibm.ws.exception.WsEJBException: nested exception is: java.lang.StackOverflowError
      at com.ibm.ejs.container.LocalExceptionMappingStrategy.mapException(LocalExceptionMappingStr ategy.java:203)
      at com.ibm.ejs.container.LocalExceptionMappingStrategy.mapCSITransactionRolledBackException( LocalExceptionMappingStrategy.java:410)
      at com.ibm.ejs.container.EJSContainer.postInvoke(EJSContainer.java:4092)
      This exception just occurred once and cannot retry.
      Previously I have ran many times and it never happened before.
      Is there any possible reason that makes java.lang.StackOverflowError happen in this case?
      Thank you and regards,
      Anh
        • 1. Re: StackOverFlowError when task is assigned to user
          Jon Bionda Level 3
          There was a bug in the event processing that caused a stack overflow but it was fixed a long time ago. I get an error opening your attached zip so i can't look at that.  What version and service pack level of ES are you running?
          ES = LC 8.0.1.sp#,
          ES Update1 = LC 8.2.1.sp#
          ES 2 = LC 9.0.0  (no sp available yet)
          Jon
          • 2. Re: StackOverFlowError when task is assigned to user
            vu.tuan.anh Level 1
            Hi  Jon,
            Thank you for your reply.
            My client uses Livecycle ES 8.2.1 SP2
            I paste the exception here in case the zip file has problem (but i still can open and view it ...):
            at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EJSLocalStatelessEjbTransactionCMTAdapter_ caf58c4f.doSupports(Unknown Source)
            at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute(EjbTransactionProvi der.java:104)
            at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor.intercept(TransactionInt erceptor.java:72)
            at com.adobe.idp.dsc.interceptor.impl.RequestInterceptorChainImpl.proceed(RequestInterceptor ChainImpl.java:60)
            at com.adobe.idp.dsc.interceptor.impl.InvocationStrategyInterceptor.intercept(InvocationStra tegyInterceptor.java:55)
            at com.adobe.idp.dsc.interceptor.impl.InvalidStateInterceptor.intercept(InvalidStateIntercep tor.java:37)
            at com.adobe.idp.dsc.interceptor.impl.AuthorizationInterceptor.intercept(AuthorizationInterc eptor.java:109)
            at com.adobe.idp.dsc.interceptor.impl.JMXInterceptor.intercept(JMXInterceptor.java:48)
            at com.adobe.idp.dsc.engine.impl.ServiceEngineImpl.invoke(ServiceEngineImpl.java:115)
            at com.adobe.idp.dsc.routing.Router.routeRequest(Router.java:110)
            at com.adobe.idp.dsc.provider.impl.base.AbstractMessageReceiver.routeMessage(AbstractMessage Receiver.java:91)
            at com.adobe.idp.dsc.provider.impl.vm.VMMessageDispatcher.doSend(VMMessageDispatcher.java:21 5)
            at com.adobe.idp.dsc.provider.impl.base.AbstractMessageDispatcher.send(AbstractMessageDispat cher.java:57)
            at com.adobe.idp.dsc.clientsdk.ServiceClient.invoke(ServiceClient.java:208)
            at com.adobe.workflow.engine.PEUtil.invokeAction(PEUtil.java:724)
            at com.adobe.workflow.engine.SynchronousBranch.handleInvokeAction(SynchronousBranch.java:466 )
            at com.adobe.workflow.engine.SynchronousBranch.execute(SynchronousBranch.java:863)
            at com.adobe.workflow.engine.ProcessEngineBMTBean.continueBranchAtAction(ProcessEngineBMTBea n.java:2773)
            at com.adobe.workflow.engine.ProcessEngineBMTBean.asyncContinueBranchCommand(ProcessEngineBM TBean.java:2528)
            at com.adobe.workflow.engine.EJSLocalStatelessadobe_ProcessEngineBMTEJB_7d3cbd67.asyncContin ueBranchCommand(Unknown Source)
            at com.adobe.workflow.engine.ProcessCommandControllerBean.doOnMessage(ProcessCommandControll erBean.java:144)
            at com.adobe.workflow.engine.ProcessCommandControllerBean.onMessage(ProcessCommandController Bean.java:99)
            at com.ibm.ejs.container.MessageEndpointHandler.invokeMdbMethod(MessageEndpointHandler.java: 1014)
            at com.ibm.ejs.container.MessageEndpointHandler.invoke(MessageEndpointHandler.java:747)
            at $Proxy0.onMessage(Unknown Source)
            at com.ibm.ws.sib.api.jmsra.impl.JmsJcaEndpointInvokerImpl.invokeEndpoint(JmsJcaEndpointInvo kerImpl.java:201)
            at com.ibm.ws.sib.ra.inbound.impl.SibRaDispatcher.dispatch(SibRaDispatcher.java:788)
            at com.ibm.ws.sib.ra.inbound.impl.SibRaSingleProcessListener$SibRaWork.run(SibRaSingleProces sListener.java:585)
            at com.ibm.ejs.j2c.work.WorkProxy.run(WorkProxy.java:419)
            at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1497)
            Caused by: java.lang.StackOverflowError
            at java.util.ArrayList.readObject(ArrayList.java:617)
            at sun.reflect.GeneratedMethodAccessor30.invoke(Unknown Source)
            at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
            at java.lang.reflect.Method.invoke(Method.java:618)
            at java.io.ObjectStreamClass.invokeReadObject(ObjectStreamClass.java:1036)
            at java.io.ObjectInputStream.readSerialData(ObjectInputStream.java:1848)
            at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:1755)
            at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1341)
            at java.io.ObjectInputStream.defaultReadFields(ObjectInputStream.java:1947)
            at java.io.ObjectInputStream.readSerialData(ObjectInputStream.java:1871)
            at java.io.ObjectInputStream.readObject(ObjectInputStream.java:378)
            at java.io.ObjectInputStream.defaultReadObject(ObjectInputStream.java:509)
            at com.adobe.workflow.pat.service.PATExecutionContextImpl.readObject(PATExecutionContextImpl .java:1377)
            at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
            at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:79)
            at java.util.HashMap.readObject(HashMap.java:1318)
            at sun.reflect.GeneratedMethodAccessor18.invoke(Unknown Source)
            at com.adobe.idp.jobmanager.ejb.JobManagerBean.deserializeObject(JobManagerBean.java:1481)
            at com.adobe.idp.jobmanager.ejb.JobManagerBean.createJob(JobManagerBean.java:188)
            at com.adobe.idp.jobmanager.ejb.EJSLocalStatelessJobManagerBeanLocalEJB_f3d02f9b.createJob(U nknown Source)
            at com.adobe.idp.jobmanager.service.JobManagerService.createJob(JobManagerService.java:77)
            at sun.reflect.GeneratedMethodAccessor389.invoke(Unknown Source)
            at com.adobe.idp.dsc.component.impl.DefaultPOJOInvokerImpl.invoke(DefaultPOJOInvokerImpl.jav a:118)
            at com.adobe.idp.dsc.interceptor.impl.InvocationInterceptor.intercept(InvocationInterceptor. java:140)
            at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor$1.doInTransaction(Transa ctionInterceptor.java:74)
            at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.execute(EjbTr ansactionCMTAdapterBean.java:342)
            at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.doSupports(Ej bTransactionCMTAdapterBean.java:212)
            ... 34 more
            Regards,
            Anh
            • 3. Re: StackOverFlowError when task is assigned to user
              Jon Bionda Level 3
              I was able to open the zip and confirmed that this bug has been fixed on 8.2.1.2.  I think you have to contact support to get it.  fix id = QF 2.62.
              Jon
              • 4. Re: StackOverFlowError when task is assigned to user
                vu.tuan.anh Level 1
                Hi Jon,
                Thank you for your reply. I will contact Adobe support for this issue.
                Regards,
                Anh
