2 Replies Latest reply on Oct 2, 2007 12:42 PM by HKabaker
    Deleting all index entries from designer
    barb_documentation
      How do I delete all the index entries on the Index Designer? It seems you can only delete one at a time. Do I have to open the HHK file to delete all the index entries? And if yes, do I leave any text in the HHK file?
        • 1. Re: Deleting all index entries from designer
          RoboColum(n) Level 5
          Hi barb_documentation and welcome to the RH communiyy.
          You can just keep your finger pressed down on the delete key. It deletes the entries one at a time but it's fairly quick. The other option is to close the project and edit the .HHK file. An empty file should look like:
          <html>
          <!-- Sitemap 1.0 -->
          <object type="text/site properties">
          <param name="SiteType" value="index">
          </object>
          <ul>
          </ul>
          </html>
          • 2. Re: Deleting all index entries from designer
            HKabaker Level 2
            Even easier,
            With RoboHelp not running, in Windows rename the HHK file just to have a backup. It doesn't matter whether you move it or leave it there.
            Launch the project in RH, which will generate a new, initialized HHK file. If you change your mind and want to go back to the original, rename the newer one and restore the original name to the original HHK file.
            A little trickier, but doable, is merging the two HHK files with a text editor (RH not running), if that's what you need.
            HK
