3 Replies Latest reply on Feb 3, 2010 11:50 AM by didier.ljc
    help with cfgrid / component
    didier.ljc
      Hey everyone...
      I'm working on the following piece code
      <cfinvoke
      component="elements.assets.cf.components.Reports"
          method="pKreport"
          returnvariable="qryKres">
      </cfinvoke>
      <cfform name="Kform">
          <cfgrid name="pKreport"
              bindonload="true"
              sort="yes"
              highlighthref="yes"
              griddataalign="left"
              gridlines="yes"
              selectmode="row"
              insertbutton="Add"
              deletebutton="Delete"
              enabled="yes"
              visible="yes"
              format="html"
              preservepageonsort="false"
              striperows="yes"
              selectonload="false"
              autowidth="false"
              pagesize="100"
      bind="cfc:elements.assets.cf.components.Reports.pKreport({cfgridpage},{cfgridpagesize},{cf gridsortcolumn},{cfgridsortdirection})">
              <cfgridcolumn name="buildingName"
                  header="Building Name"
                  headeralign="left"
                  dataalign="left"
                  select="no"
                  display="yes"
                  headerbold="yes" />
              <cfgridcolumn name="allocatedSF"
                  header="Allocated SF"
                  headeralign="left"
                  dataalign="left"
                  select="no"
                  display="yes"
                  headerbold="yes" />
              <cfgridcolumn name="capacity"
                  header="Capacity"
                  headeralign="left"
                  dataalign="left"
                  select="no"
                  display="yes"
                  headerbold="yes" />
              <cfgridcolumn name="occupancy"
                  header="Occupancy"
                  headeralign="left"
                  dataalign="left"
                  select="no"
                  display="yes"
                  headerbold="yes" />
              <cfgridcolumn name="vacancy"
                  header="Vacancy"
                  headeralign="left"
                  dataalign="left"
                  select="no"
                  display="yes"
                  headerbold="yes" />
          </cfgrid>
      </cfform>
      But I keep getting the following error - and I'm not sure why...
      ___________________________________________________________________________
      The specified  CFC elements.assets.cf.components.Reports could not be found.
      The path to the CFC must be  specified as a full path, or as a relative path from the current template,  without the use of mappings.
      I'm using the same component in both the cfinvoke & cfgrid -- it works fine with the cfinvoke...
