0 Replies Latest reply on Feb 2, 2010 10:59 PM by rayavoy
    Flex desktop app with embedded browser incompatible with asp.net ToolkitScriptManager??
    rayavoy
      Hi, I have a website that's developed in ASP.NET and uses the AJAX Toolkit (asp:ToolkitScriptManager) for a couple of extenders. The AJAX effects (e.g. ) work perfectly across IE 7, IE8, FF3.5, Safari, and Chrome. However, I embedded my site in a desktop Flex-AdobeAir application using the component which is able to run the entire site including javascript except where the AJAX is used.
      I narrowed the source of the problem down to the difference between using asp:ToolkitScriptManager and asp:ScriptManager. Here's an example page that will display "Safari" in the embedded flex browser as the result of document.write(Sys.Browser.name):
      <%@ Page Language="C#" %>
      <%@ Register assembly="AjaxControlToolkit" namespace="AjaxControlToolkit" tagprefix="asp" %>
      <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
      <html xmlns="http://www.w3.org/1999/xhtml" >
      <head id="Head1" runat="server">
      <title>Flex test</title>
      </head>
      <body>
      <form runat="server">
      <asp:ScriptManager ID="TheScriptManager" runat="server"></asp:ScriptManager>
                        document
      .write(Sys.Browser.name);
      </script>
      </form>
      </body>
      </html>
      However, if you change
      to
      <asp:ToolkitScriptManager ID="TheScriptManager" runat="server"></asp:ToolkitScriptManager>
      it suddenly does not display anything on the flex browser.
      Can anyone help?  Thank you.
