7 Replies Latest reply on Feb 3, 2010 11:44 AM by Francisc
    Removing Event Listeners
    Francisc Level 3
      Hello!
      I have a PopUpManager window that fires an event just before closing (not the CloseEvent).
      I am listening for that event and handling it in a function.
      Q: Is it best practice to remove the listener in the function that handles it or calling PopUpManager.removePopUp on that popup automatically does the "cleaning" as well?
      Thank you!
        • 1. Re: Removing Event Listeners
          archemedia Level 4
          where and how are you adding the event listener?
          Dany
          • 2. Re: Removing Event Listeners
            Francisc Level 3
            The listener gets added right after the PopUpManager.addPopUp is called.
            The handling function is inside the parent of the pop up window, the window just has a form and fires an even after data is sent.
            • 3. Re: Removing Event Listeners
              archemedia Level 4
              Removing the eventListeners on a popup window is necessary I believe.
              In your event handling function, you can remove the event listener by event.target.removeEventListener(..., ...). It doesn't matter that your component is handle by the popUpManager, you'll still have a reference to it.
              Example
              In main app:
              var win:myClass = PopUpManager.createPopUp(this, myClass, true) as myClass;
              win.addEventListener("myEvent", myHandler);
              private function myHandler(evt:Event):void
                   evt.target.removeEventListener("myEvent", myHandler);
              In custom myClass:
              private function handleSomething(evt:Event):void
                              var ev:Event = new Event("myEvent");
                              dispatchEvent(ev);
                              if (isPopUp)
                                  PopUpManager.removePopUp(this as IFlexDisplayObject);
              Does this help?
              Dany
              • 4. Re: Removing Event Listeners
                Francisc Level 3
                I know how to do it, I was just wondering if I should do it or if the removePopUp will leave it to the Garbage Collector...
                So I take it I am responsbile for cleaning the `mess` up?
                • 5. Re: Removing Event Listeners
                  archemedia Level 4
                  All the articles I found on this subject warn to remove the event listeners, so I think they're right.
                  On the other hand, I couldn't find an adobe article stating this.
                  So, until further notice, I guess it's safest to remove them. I found out that I forgot to do that in one of my projects too
                  Dany
                  • 6. Re: Removing Event Listeners
                    Flex harUI Adobe Employee
                    A listener simply creates a reference from the dispatcher to the listener.
                    In the code below, there is now a reference from "win" to the class that
                    owns "myHandler" which is the document, so adding that listener will not
                    cause a leak.
                    • 7. Re: Removing Event Listeners
                      Francisc Level 3
                      There is no code below, but I understand what you are saying! Thanks!
