3 Replies Latest reply on Feb 4, 2010 2:04 AM by Peter Kahrel
    [JS CS3] RegExp Object containing only one backslash (how to escape)
    Stefan Huwiler
      Hi
      I'm trying to escape one backslash in my RegExp Object, but I get a Syntax Error:
           myObj = new RegExp ( "\\" );
      I tried it phyton Style   myObj = new RegExp ( "\\\\" ); but that's not working right.
      Thanks for any hint.
      Stefan
        • 1. Re: [JS CS3] RegExp Object containing only one backslash (how to escape)
          Peter Kahrel Adobe Community Professional & MVP
          works fine for me. In what way does it not work? Can you give a slightly larger fragment?
          Peter
          • 2. Re: [JS CS3] RegExp Object containing only one backslash (how to escape)
            Stefan Huwiler Level 1
            Hi Peter
            Here's an example (Usually the Text would come from outside (e.g Document Text or external Text File):
            #target InDesign
            main();
            exit();
            function myReplaceExample( myText, myWhatSearch, myWhat, myWhit)
                 if ( myText.search( myWhatSearch ) )
                      myText = myText.replace( myWhat, myWhit );
                 return myText;
            // Main
            function main()
                 var myText = "This is an \\ of search and replace.";
                 var myWhat = "\\";
                 var myWhatSearch = new RegExp ( "\\\\" );
                 var myWhit = new RegExp ( "example" );
                 alert( myReplaceExample( myText, myWhatSearch, myWhat, myWhit) );
                 return true;
            The result is his is an /example/ of search and replace.
            Stefan
            • 3. Re: [JS CS3] RegExp Object containing only one backslash (how to escape)
              Stefan,
              First of all, in your sample text you need to escape your backslash as well:
              You can see this in these examples:
              alert ("a\rb") prints "a" then "b" on a new line; alert ("a\\rb") prints "a\rb".
              Another problem is that you use a regex as the replacement object (myWhit), but that should be a string. With these two things corrected, it works fine:
              function main()
                   var myWhat = new RegExp ( "\\\\" );
                   var myWhit = "example";
                   return true;
              That new RegExp ("\\") can't be correct can be seen if you start with a literal regex, in which you would use an escaped backslash:
              myText = myText.replace (/\\/, "example")
              To use \\ in a new RegExp () construction, you need to place it in a string, and you need to escape both backslashes, so you end up with "\\\\".
              Peter
