2 Replies Latest reply on Feb 9, 2010 12:37 AM by adrienne25
    faultCode = "Client.Error.MessageSend"   faultDetail = "Channel.Security.Error error Error #2048
    adrienne25
      I am running Windows Vista as my OS and have installed Zend Server that already has Apache, MySQL, PHPMyAdmin, they are running on port 85.  I have installed a single instance of Coldfusion 8 to run on my system.  I used the Flex Builder 3 Coldfusion database wizard to create a database application that was connected to a the local mysql database.  The Flex Project is located in the web root of my apache server which is on port 85 along with cfide for coldfusion 8 (I do not have the default coldfusion server on 8500 installed) even though I only have one instance of coldfusion with my apache webserver, I do have IIS installed on port 90 and at one point had jrun with a multiserver configuration of coldfusion but because of this problem I have uninstalled coldfusion and reinstalled a standalone copy on just my Apache Server with Zend.  My project would not validate without the settings that I have Standalone instance of Coldfusion and the root is C:\ColdFusion8 and for my web server I have C:\Program Files\Zend\Apache2\htdocs and http://localhost:85 for the url.  I got the same error message when I just had the default services-config.xml file and just using localhost for my url (I have another instance of apache on localhost), I then changed my services-config.xml to reflect the remote server I will deploy this app to.  When trying to deploy this project I get the following error message:
        content = (Object)#1
        errorID = 0
        faultDetail = "Channel.Security.Error error Error #2048 url: 'http://cfdeveloper-sql1.lnc.net:3306/flex2gateway/'"
        faultString = "Send failed"
        message = "faultCode:Client.Error.MessageSend faultString:'Send failed' faultDetail:'Channel.Security.Error error Error #2048 url: 'http://cfdeveloper-sql1.lnc.net:3306/flex2gateway/''"
        name = "Error"
        rootCause = (mx.messaging.events::ChannelFaultEvent)#2
          bubbles = false
          cancelable = false
          channel = (mx.messaging.channels::AMFChannel)#3
            authenticated = false
            channelSets = (Array)#4
              [0] (mx.messaging::ChannelSet)#5
                channelIds = (Array)#6
                  [0] "my-cfamf"
                channels = (Array)#7
                  [0] (mx.messaging.channels::AMFChannel)#3
                clustered = false
                connected = false
                currentChannel = (mx.messaging.channels::AMFChannel)#3
                initialDestinationId = (null)
                messageAgents = (Array)#8
                  [0] (mx.rpc::AsyncRequest)#9
                    autoConnect = true
                    channelSet = (mx.messaging::ChannelSet)#5
                    clientId = (null)
                    connected = false
                    defaultHeaders = (null)
                    destination = "ColdFusion"
                    id = "E46AB1D5-6C27-45AB-3D52-90DF65B6DBAA"
                    reconnectAttempts = 0
                    reconnectInterval = 0
                    requestTimeout = -1
                    subtopic = ""
                  [1] (mx.rpc::AsyncRequest)#10
                    autoConnect = true
                    clientId = (null)
                    connected = false
                    id = "0E524423-DF39-9573-91BC-90F1C3BE6654"
                    requestTimeout = -1
                    subtopic = ""
            connected = false
            connectTimeout = -1
            enableSmallMessages = true
            endpoint = "http://cfdeveloper-sql1.lnc.net:3306/flex2gateway/"
            failoverURIs = (Array)#11
            id = "my-cfamf"
            mpiEnabled = false
            netConnection = (flash.net::NetConnection)#12
              client = (mx.messaging.channels::AMFChannel)#3
              connected = false
              objectEncoding = 3
              proxyType = "none"
              uri = "http://cfdeveloper-sql1.lnc.net:3306/flex2gateway/"
            piggybackingEnabled = false
            polling = false
            pollingEnabled = false
            pollingInterval = 3000
            protocol = "http"
            reconnecting = false
            recordMessageSizes = false
            recordMessageTimes = false
            requestTimeout = -1
            url = "http://cfdeveloper-sql1.lnc.net:3306/flex2gateway/"
            useSmallMessages = false
          channelId = "my-cfamf"
          connected = false
          currentTarget = (mx.messaging.channels::AMFChannel)#3
          eventPhase = 2
          faultCode = "Channel.Security.Error"
          faultDetail = "Error #2048 url: 'http://cfdeveloper-sql1.lnc.net:3306/flex2gateway/'"
          faultString = "error"
          rejected = false
          rootCause = (flash.events::SecurityErrorEvent)#13
            bubbles = false
            cancelable = false
            currentTarget = (flash.net::NetConnection)#12
            eventPhase = 2
            target = (flash.net::NetConnection)#12
            text = "Error #2048"
            type = "securityError"
          target = (mx.messaging.channels::AMFChannel)#3
          type = "channelFault"
      I have no idea and have changed everything I can think of,  please help!
