0 Replies Latest reply on Oct 17, 2006 4:35 PM by
    Movie accessing loaded movie
      I have a movie called 'interface.swf' and it loads in another movie from the same folder called 'main.swf' into an empty movieclip.
      I then call functions inside main.swf from interface.swf.
      If I run interface.swf from a local folder, it will not work unless the location is added as a trusted in the Flash Player settings manager.
      If I run it through a web server, no problem.
      The problem is now, that I am trying to run this as a SCORM package through moodle, and moodle runs from a different folder on the webroot then where is stores it's files, and again it will not work.
      For Example:
      http://mysite/moodle - is where the application is ran from.
      http://mysite/moodledata - is where the swf files are stored.
      The path Moodle uses to play the files, which DOES NOT WORK is:
      But, if I call the file directly where it is stored, it does work:
      Notice, the file.php in the URL that does not work, I think this file passes the files so how.
      I have tried crossdomain.xml files, but I am not sure if they apply to this.
      Any Ideas?
