18 Replies Latest reply on Feb 4, 2010 8:01 AM by beno12345
    What Argument?
    beno12345 Level 1
      Hi;
      I have the following code that is called from another class:
      package
      import flash.events.Event;
      import flash.events.ProgressEvent;
      import flash.events.MouseEvent;
      import flash.display.MovieClip;
      import com.greensock.*;
      import com.greensock.easing.*;
      public class CloseThumb extends MovieClip
      public var myThumb:CloseThumb;
      public function CloseThumb()
      init();
      public function init():void
      theThumb();
      trace('init CloseThumb');
      public function doTween():void
      trace('doTween');
      TweenMax.to(myThumb, .4, {shortRotation:{rotation:60}, ease:Back.easeOut,onComplete:onFinishTween});
      public function onFinishTween():void
      removeChild(myThumb);
      public function theThumb():void
      myThumb.x = 365;
      myThumb.y = 355;
      addChild(myThumb);
      doTween();
      trace('theThumb');
      Calling this code from the other class throws this error:
      1136: Incorrect number of arguments. Expected 1.
      What argument is it expecting from the above code?
      TIA,
      beno
        • 1. Re: What Argument?
          click file/publish settings/flash and tick "permit debugging".  retest and paste the output.
          • 2. Re: What Argument?
            beno12345 Level 1
            I did just that and it didn't give me anything else. I even double-checked to see that "Permit debugging" was checked. Please advise.
            TIA,
            beno
            • 3. Re: What Argument?
              how do you know the error is coming from that class?  do you see any trace() output?
              • 4. Re: What Argument?
                beno12345 Level 1
                The source of the error states it's coming from CloseThumb.as, which is the class in question.
                • 5. Re: What Argument?
                  again, copy and paste the complete error message including trace output after inserting a trace() function just before call theThumb().
                  in addition, how does this class obtain a reference to myThumb?
                  • 6. Re: What Argument?
                    beno12345 Level 1
                    Just to be really clear, I changed the CloseThumb.as thus:
                    trace('theThumb');
                    theThumb();
                    It didn't trace at all. I believe the reason is because, as the error states, Flash is expecting me to put an argument into my call to CloseThumb() and I'm not doing that:
                    Main2.as, Line 28          1136: Incorrect number of arguments. Expected 1.          CloseThumb()
                    For good measure (and to answer your other question), here's the code from which it is called:
                    package
                    import CloseThumb;
                    public class Main2 extends MovieClip
                    trace('hi');
                    private var myThumb:CloseThumb = new CloseThumb();
                    public function Main2()
                    trace('Main2');
                    init();
                    trace('init');
                                            CloseThumb();
                    I'd forgotten this until just now, but it's not tracing *anything at all*.
                    TIA,
                    beno
                    • 7. Re: What Argument?
                      what's myThumb?  (CloseThumb has no way to reference a displayobject.)
                      and:
                      package
                      import CloseThumb;
                      trace('hi');
                      trace('Main2');
                      init();
                      trace('init');
                                              CloseThumb();  // this is wrong.
                      • 8. Re: What Argument?
                        beno12345 Level 1
                        I *think* I see the problem, but I probably have not understood you correctly. CloseThumb is also the name of a library asset in the IDE, so I changed the name of the class and the *.as file to CloseTheThumb, giving me the following revised code:
                        public class CloseTheThumb extends MovieClip
                        public var myThumb:CloseThumb = new CloseThumb();
                        public function CloseTheThumb()
                        but that didn't make one bit of difference. To answer your question, myThumb is an instantiation of the CloseThumb in the library.
                        TIA,
                        beno
                        • 9. Re: What Argument?
                          beno12345 Level 1
                          Oops. Ok, changed to:
                          CloseTheThumb();
                          package
                          import CloseTheThumb;
                          trace('hi');
                          trace('Main2');
                          init();
                          trace('init');
                                                  CloseTheThumb();
                          but it *still* throws the same error:
                          1136: Incorrect number of arguments. Expected 1      Source: CloseTheThumb
                          Please advise.
                          TIA,
                          beno
                          • 10. Re: What Argument?
                            what's CloseTheThumb()?
                            • 11. Re: What Argument?
                              beno12345 Level 1
                              CloseTheThumb() is what used to be CloseThumb(). It's a separate class. The reason I renamed it is because of a name conflict with a library asset by the same name.
                              beno
                              • 12. Re: What Argument?
                                then what's CloseThumb?
                                • 13. Re: What Argument?
                                  beno12345 Level 1
                                  CloseThumb is the library asset.
                                  CloseTheThumb is the class.
                                  Hope that clears up the confusion.
                                  beno
                                  • 14. Re: What Argument?
                                    this isn't correct:
                                    trace('init');
                                                            CloseTheThumb();
                                    what do you expect to happen when you "call" a class?  that's not a function/method.
                                    look, you're entire setup is screwy.  if CloseThumb is your library asset, create a CloseThumb class that includes a public method to "close" or tween your asset.  you can then apply that method to all your CloseThumb instances whenever you like.
                                    • 15. Re: What Argument?
                                      beno12345 Level 1
                                      Well, that's what CloseTheThumb is supposed to be! So I tried sticking
                                      doTween();
                                      in the Main2.as class, but it errors out, naturally, as a call to a possibly undefined method since it's not a method at all, it's a function. Sorry...I'm obviously new at this :-}
                                      TIA,
                                      beno
                                      • 16. Re: What Argument?
                                        beno12345 Level 1
                                        Never mind. I believe I've figured this out. Thanks for your help!
                                        beno
                                        • 17. Re: What Argument?
                                          assign the Thumb class to your library asset and create the following Thumb class:
                                          package
                                          public class Thumb extends MovieClip
                                          public function Thumb(x:int,y:int)
                                          setPos(x,y);
                                          trace('doTween');
                                          TweenMax.to(this, .4, {shortRotation:{rotation:60}, ease:Back.easeOut,onComplete:onFinishTween});
                                          this.parent.removeChild(this);
                                          // consider nulling for gc
                                          public function setPos(x:int,y:int):void
                                          this.x = x;
                                          this.y = y;
                                          now, in your document class, when you want to create a new Thumb instance use:
                                          var thumb:Thumb=new Thumb(100,200);  // or use whatever intial x,y
                                          addChild(thumb);
                                          when you want to tween and remove your thumb use:
                                          thumb.doTween();
                                          • 18. Re: What Argument?
                                            beno12345 Level 1
                                            Yes, that's basically what I did. You must have been working on this while I posted I'd solved the problem. Thanks again!
                                            beno
