4 Replies Latest reply on Feb 3, 2010 11:57 AM by PeakDigital
    Sorting then adding an item
    Francisc Level 3
      Hello!
      I have an AC with names.
      I want to sort it everytime a name changes but keep as the first item "Select name" as I use it for a ComboBox.
      What I do and does not work is this:
      public function sortAC():void
           myAC.removeItemAt(0);//Remove the "Select name" item so I can sort and add it at the end again.
           var dataSortField:SortField=new SortField();
           dataSortField.name='name';
           var dataSort:Sort=new Sort();
           dataSort.fields=[dataSortField];
           myAC.sort=dataSort;
           myAC.refresh();
           myAC.addItemAt({'id':0,'name':'Select Name''},0);//add the top value again after sorting and refreshing
      The problem is "Select Name" gets placed alphabetically in the list as it should if sorted.
      How can I keep it on top and still sort please?
      Thank you!
