5 Replies Latest reply on Feb 3, 2010 5:25 PM by kglad
    cs4 parameters - can't find path for xml file
    in oz
      I am trying to build a .xml image scroller using the scroll pane component in CS4.
      I choose Actionscript3. Drag the component to the stage. Give it an instance name.
      Then I look for the Parameters that used to be in the properties panel in CS3. Not there anymore.
      I find that the Components Inspector has Parameters in there now.
      OK.
      I need to use ContentPath to tell the component where the .xml file is so it can find the images for the scroller.
      Can't find 'ContentPath'.
      How can I point the component to a .xml file?
      Is there a way of getting Parameters back in with properties - it was so much easier.
      Thank you.
