3 Replies Latest reply on Feb 4, 2010 11:00 AM by Flex harUI
    Can a module unload itself?
    Scott R. Hamilton Level 1
      I would like to be able to load a module that returns a
      value to its calling module or applications and then
      unloads itself.
      I cannot find an example in the documentation of this being
      done although it seems that this would be a typical sort of
      thing that developers would want to be able to do.
      Scott
        • 1. Re: Can a module unload itself?
          Flex harUI Adobe Employee
          Module loading is asynchronous so you can't "return" something.  If the
          module class has a method on it that you call the in the ready handler of
          the loading app you would call factory.create() then the method and as long
          as you didn't store the instance anywhere permanent it would be garbage
          collected at some point and the module would unload
          • 2. Re: Can a module unload itself?
            Hi Alex,
            what I would like to do is load a module that allows the user to enter
            filter criteria and then select records in the data base.
            He/she then marks one of the retrieved records in a datagrid and
            presses a "Select" button.
            The filter/select module should write the record key of the selected
            record back to the calling module and control should return to the
            calling module.
            I should be able to use the parentApplication specifier to write
            the data to a field in the caller. But when I try to get the the
            called module to unload using:
            parentApplication.TargetModule.url = null;
            both modules get unloaded.
            Scott
            • 3. Re: Can a module unload itself?
              Hard to say what the problem is.  Remember that parentApplication is not the
              same as "parent module".  Make sure you have a strong reference from the
              main app to the calling module otherwise it might be that the filter module
              is the only thing preventing the calling module from being garbage
              collected.  Also check the code that loads modules to make sure you are
              using the applicationDomain parameters correctly.
