1 Reply Latest reply on Mar 1, 2017 10:20 AM by [fhcon]ohaeuser
    IDML to PDF using Java API
    RithanyaLaxmi Level 1
         I have created an IDML with template through the Indesign GUI and have created the respective XML files(story,designmap,etc) and able to make the changes in it and display that in the UI. This is fine, my requirement is to use the Java API to pass the .idml file (which holds the template) and creates a .PDF out of this. I am unable to get any source code samples for this, this should be done through Java API and no scripting is allowed. I went through the IDML spec, but doesn't have any source code samples for the requirement. Hence, please do provide the source code samples to achieve this using Java API. Expecting positive response...
      Rithu
