2 Replies Latest reply on Feb 4, 2010 10:26 AM by chuck_w2010
    Adobe Premium Suite installation problem....
    chuck_w2010
      Hello,
      First I am new to this forum.
      The problem.....
      Last night I was installing my adobe suite and a problem occured. At 46% installation disk 1 the installation got hung up. It looks like adobe media player was being installed at that point. I waited at least 10 minutes to see if it would continue and it did not. I restarted the install and deselected adobe media player and the installation went through ok. Could there be a problem with the disk? Should I ask adobe for a replacement disk?
      Thanks in advance
        • 1. Re: Adobe Premium Suite installation problem....
          Unlikely. It's more likely you had/ have a newer version of Adobe AIR/ AMP already on your system, causing an installer failure because it cannnot overwrite the files...
          Mylenium
          • 2. Re: Adobe Premium Suite installation problem....
            chuck_w2010 Level 1
            Mylenium
            Mylenium,
            Thanks for that response but......
            I never had adobe AIR/AMP installed before so could it really be the problem?
            What about this idea.....if i download the entire Design suite and reinstall using the download instaed of the disks
            but use my serial number then will it work properly? what do you think?
