3 Replies Latest reply on Feb 4, 2010 1:56 PM by Gregory Lafrance
    Access datagrid column from another column
    flex.net
      Hello
      Basically, I have 2 columns in a DataGrid, both with CheckBox itemRenderers.
      When I check the first checkbox, I want the second to be enabled = false.  I'm stuck.
      Thanks!
        • 1. Re: Access datagrid column from another column
          Gregory Lafrance Level 6
          This answers your question:
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml">
            <mx:Script>
              <![CDATA[
                import mx.events.ListEvent;
                import mx.collections.ArrayCollection;
                [Bindable] private var ac:ArrayCollection = new ArrayCollection([
                  {oneSelected: false, twoSelected: false, twoEnabled: true},
                public function changeEnabled(evt:ListEvent):void{
                  var origData:Object = ac.getItemAt(evt.rowIndex);
                  origData.twoEnabled = origData.twoEnabled == false?true:false;
                  ac.setItemAt(origData, evt.rowIndex);
            </mx:Script>
            <mx:DataGrid dataProvider="{ac}" itemClick="changeEnabled(event)">
              <mx:columns>
                <mx:DataGridColumn dataField="oneSelected">
                  <mx:itemRenderer>
                    <mx:Component>
                      <mx:CheckBox selectedField="oneSelected"
                        change="onChange(event);" label="">
                        <mx:Script>
                          <![CDATA[
                            private function onChange(evt:Event):void {
                              data.oneSelected = !data.oneSelected;
                        </mx:Script>
                      </mx:CheckBox>
                    </mx:Component>
                  </mx:itemRenderer>
                </mx:DataGridColumn>
                <mx:DataGridColumn dataField="twoSelected">
                  <mx:itemRenderer>
                    <mx:Component>
                      <mx:CheckBox selectedField="twoSelected"
                        change="onChange(event);" label="" enabled="{data.twoEnabled}">
                        <mx:Script>
                          <![CDATA[
                              data.twoSelected = !data.twoSelected;
                        </mx:Script>
                      </mx:CheckBox>
                    </mx:Component>
                  </mx:itemRenderer>
              </mx:columns>
            </mx:DataGrid>
          </mx:Application>
          If this post answers your question or helps, please mark it as such.
          Greg Lafrance - Flex 2 and 3 ACE certified
          www.ChikaraDev.com
          Flex / AIR Development, Training, and Support Services
          • 2. Re: Access datagrid column from another column
            flex.net Level 1
            Thank you, that definitely does it.
            Unfortunately, I left out some details.  My ArrayCollection is let's say, a resultset for employee data.  The 2 CheckBox fields are not part of the ArrayCollection -- they are extra columns within the DataGrid.  Do you know of a solution where I wouldn't have to modify the dataProvider?
            PS
            It wouldn't be a problem to include the 2 CheckBox fields in the ArrayCollection -- I'm just wondering.  Thanks.
            • 3. Re: Access datagrid column from another column
              Normally you need to operate on the data provider, because item renderers are recycled, and you can get strange results if you are not operating on the DP.
