1 Reply Latest reply on Feb 5, 2010 9:49 AM by Horsepower0171
    Problems with DreamweaverCS4 and FlashCS4
    Horsepower0171 Level 1
      I have created with DreamweaverCS4 this page:
      http://www.cavallodario.it/3DSMax.html
      At bottom of the page exist two Flash files.
      The first is created with Dreamweaver, and have the skin playback bar; with the menu: Insert>Common>multimedia object:FLV
      But this file appears bad, with a less frame rate, and with a jerky frames, if compared to the second Flash file.
      - Why?
      The second at very bottom of the page, is correct and is inserted as SWF file (Insert>Common>multimedia object:SWF) and created with Flash directly.
      For the first file, I selected in Dreamweaver the file:
      3dCameraTrackerRegisterSolution.flv
      with the Skin Option: "Clear Skin 3 (min width 260)" and Dreamweaver created for me the object named:"SWF:FLVPlayer"
      I tried to create the second file with FlashCS4 and Published the Flash (.swf) file, and the .HTML file, named "3dCameraTrackerRegisterSolution.html".
      You can see the last correct Flash+HTML published file at this page:
      http://www.cavallodario.it/filmati_flashCS4/3dCameraTrackerRegisterSolution.html
      In this file the Skin is visible.
      But in the previous page: http://www.cavallodario.it/3DSMax.html the same file, at very bottom of the page, is the second Flash file that doesn't display the Skin!
      How can i do to display and incorporate the skin?
      Flash created other than "3dCameraTrackerRegisterSolution.swf" file, also the Skin file named: "SkinOverPlaySeekFullscreen.swf".
      - Where I should place this Skin file in Dreamweaver?
      I want incorporate, in Dreamweaver, this Skin file (made with Flash) in the "3dCameraTrackerRegisterSolution.swf" file, in the same manner of HTML file "3dCameraTrackerRegisterSolution.html" !
      - But how I can do?
