1 Reply Latest reply on Feb 4, 2010 10:03 AM by Cr99
    xml binding errors
    Cr99 Level 1
      I am trying to get some xml parsed into different elements in my interface, but I am getting the following errors:
      warning: unable to bind to property 'width' on class 'XML' (class is not an IEventDispatcher)
      warning: unable to bind to property 'height' on class 'XML' (class is not an IEventDispatcher)
      warning: unable to bind to property 'link' on class 'XML' (class is not an IEventDispatcher)
      warning: unable to bind to property 'caption' on class 'XML' (class is not an IEventDispatcher)
      warning: unable to bind to property 'channel' on class 'XML' (class is not an IEventDispatcher)
      warning: unable to bind to property 'id' on class 'XMLList' (class is not an IEventDispatcher)
      warning: unable to bind to property 'refresh' on class 'XML' (class is not an IEventDispatcher)
      Here is a snippet from the xml file:
      <?xml version="1.0" encoding='UTF-8'?>
      <Top>
      <StaticImage id ="00">
           <caption>Static Image</caption>
           <link>http://www.mydomain.html</link>
      </StaticImage>
      <CubeFaces id="10">
         <channels>
           <channel id="0" height="1000" width="1000" refresh="1">
                <caption>Ch22</caption>
           </channel>
               <!-- etc. more channels defined.... -->
          </channels>
      </CubeFaces>
      <Background>
           <image></image>
      </Background>
      </Top>
      When I access the parent tags (e.g. channel.caption), I get the values.
      But when I try to access elements definied inside a tag (e.g. channel.id), I get nothing.
      Seems like I am just messed up on the syntax somehow?
      Here is the code I'm using to process the xml file:
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
      creationComplete="xmlFeed.send()">
           <mx:Script>
      <![CDATA[
      // imports, etc here...
      [Bindable]
              private var dbURL:String = "http://localhost:8888/myproj/kiosk";
              [Bindable]
              private var fileContents:XML;
              private function processXML(event:ResultEvent):void {
              fileContents = event.result as XML;
              trace (fileContents);
           </mx:Script>
      <mx:HTTPService id="xmlFeed" useProxy="false" method="GET" showBusyCursor="true" resultFormat="e4x"
      fault="UtilityTools.handleFault(event);" url="{dbURL}" result="processXML(event)"/>
      <mx:Accordion id="accordion">
              <mx:VBox label="Cube Faces">
                  <mx:Repeater id="xmlTags" dataProvider="{fileContents.CubeFaces.channels.channel}">
                  <mx:HBox width="100%">
                  <mx:Label text="ID"/>
                  <mx:TextInput text="{xmlTags.currentItem.id}" width="30"/> <!-- id doesn't work -->
                  <mx:Label text="Height"/>
                  <!-- etc more elements defined here -->
                  <mx:TextInput text="{xmlTags.currentItem.caption}" width="60"/> <!-- caption works -->
                  </mx:HBox>
                  <mx:HBox paddingLeft="10">
                  <mx:Label text="Link"/>
                  <mx:TextInput text="{xmlTags.currentItem.link}"/>
                  </mx:HBox>
                  </mx:Repeater>
              </mx:VBox>
                <!-- etc. more elements defined here -->
               </mx:Accordion>
      </mx:Application>
