4 Replies Latest reply on Feb 4, 2010 7:37 PM by emmanueldecarie
    [AS] Saving a file without creating an idlk file
    emmanueldecarie
      Hi there,
      I have an AppleScript that open an InDesign template (indt), import a XML file and then save the document to another folder than the one where the XML file and the template are living.
      The problem, and I don't see how to resolve it, is that InDesign always create a lock file (idlk) with the new document and I don't seem to find a way to close the new document.
      Here's the script:
      Translating:
      chemin_fichier_xml                           == path_to_xml_file
      chemin_gabarit_indesign                   == path_to_indesign_template
      chemin_nouveau_fichier_indesign      == path_to_new_indesign_file
      on genere_fichier_indesign(chemin_fichier_xml, chemin_gabarit_indesign, chemin_nouveau_fichier_indesign)
      tell application "Adobe InDesign CS4"
      set ce_document to open chemin_gabarit_indesign without showing window
      tell ce_document
      tell XML import preferences
      set import style to merge import
      set repeat text elements to true
      set import text into tables to true
      set import CALS tables to true
      end tell
      import XML from chemin_fichier_xml
      set le_nouveau_document to chemin_nouveau_fichier_indesign
      tell ce_document to save to le_nouveau_document with force save
      (* this will generate an error *)
      -- try
      -- close ce_document saving no
      -- close le_nouveau_document saving yes
      -- end try
      end tell
      end tell
      end genere_fichier_indesign
      TIA
      Cheers
      -Emmanuel
        • 1. Re: [AS] Saving a file without creating an idlk file
          sstanleyau Level 4
          If you're opening a template and want to save it as a normal document, you probably need to include the "statioery" parameter in your save. Try something like this:
          tell ce_document to save to le_nouveau_document without stationery
          close document 1 saving no
          • 2. Re: [AS] Saving a file without creating an idlk file
            emmanueldecarie Level 1
            Hello,
            Thanks for replying.
            I still get an idlk file and an error.
            --> Adobe InDesign CS4 got an error: Can’t get document 1 of document "Sans titre-3"
            I tried other variation:
            close file le_nouveau_document saving no
            --> Can’t get file "HD:Users:stereo:Applications:Automatisation Téléhoraires:Dossiers:InDesign - À valider:StThomasTimesJournal_20100131_1009_1_Quot.indd" of document "Sans titre-2".
            close documents saving no
            -->  Can’t get every document of document "Sans titre-3"
            I'm on Snow Leopard 10.6.2 and use ID CS4 v6
            Cheers
            -Emmanuel
            • 3. Re: [AS] Saving a file without creating an idlk file
              sstanleyau Level 4
              You need to move outside the "tell ce_document" block. In fact, if you only have one document, you're better off just referring to document 1. The problem with references like "tell ce_document" is that "ce_document" is based on the doc's name, so as soon as you save as another document, the reference no longer works.
              • 4. Re: [AS] Saving a file without creating an idlk file
                Doh!
                Thanks a lot, it’s working perfectly now. Its part of a workflow where Hazel is monitoring a couple of folders and where the files move from folder to folder (where scripts are launched depending of the folder). A couple years ago, UserLand Frontier could have been perfect for that kind of stuff. Thanks Again!
                Cheers
                -Emmanuel
