4 Replies Latest reply on Feb 24, 2014 1:44 AM by --tristian--
    unable to set nativeapplication idleThreshold :(
    flx23
      Hi all,
      i am setting the idletime in the below code and further i have added an addeventlistener
      public var IDLE_TIME:int=10;
      NativeApplication.nativeApplication.addEventListener(Event.USER_IDLE,setModeToIdle);
      i am setting NativeApplication.nativeApplication.idleThreshold=IDLE_TIME;
      private function setModeToIdle(evt:Event):void
                      //Application.application.swfContainer.toolTip="";
                      Application.application.stage.displayState = StageDisplayState.FULL_SCREEN;
      when i set the idleThreshold to 10 which is bydefault ..if i keep the system idle for ten secs the  setModeToIdle should invoke ..but in my case it is taking the default 5 mins..of its own can any body put a light on it
      plzzzzzzzz
        • 1. Re: unable to set nativeapplication idleThreshold :(
          SpecialK
          I have also experienced this same bug. I am using Flex 3.5.0a. The workaround is that you have to set it in Application. For example, I am building an AIR app, so in my WindowedApplication preinitialize function, I am setting the idle threshold.
          preinitialize="nativeApplication.idleThreshold = IDLE_TIME"
          This is definitely a bug, as Application.application.nativeApplication just returns Nativeapplication.nativeapplication. There is no reason why this value shouldn't be respected from wherever it has been set.
          • 2. Re: unable to set nativeapplication idleThreshold :(
            jtoussaint
            I am using Flash Builder 4.5 with Flex 4.5.1 sdk.
            I am experiencing the same, unable to set the idleThreshold, neither via NativeApplication.nativeApplication.idleThreshold, nor via preinitialize="nativeApplication.idleThreshold=xx".
            I tried many alternatives, and one that worked for me was when setting the idleThreshold to 5 and exactly 5 (nothing else so far tested worked.)
            NativeApplication.nativeApplication.idleThreshold = 5;
            NativeApplication.nativeApplication.addEventListener(Event.USER_IDLE, onUserIdle);
            So I implemented a counter in the onUserIdle function.
            • 3. Re: unable to set nativeapplication idleThreshold :(
              jtoussaint Level 1
              Bug understood. The idleThreshold seems to be disabled when a videodisplay is playing (my case). I tried without playing any video and the idleThreshold works perfectly.
              • 4. Re: unable to set nativeapplication idleThreshold :(
                --tristian--
                Sorry to drag up an old thread but I've only recently come across this problem. I ended up re-adding the event listener to the nativeApplcation:
                protected function applyIdleSettings():void
                    NativeApplication.nativeApplication.idleThreshold = model.idleThreshold;
                    if( NativeApplication.nativeApplication.hasEventListener(Event.USER_IDLE) ){
                        NativeApplication.nativeApplication.removeEventListener( Event.USER_IDLE, application_userIdleHander );
                    NativeApplication.nativeApplication.addEventListener( Event.USER_IDLE, application_userIdleHander );
