3 Replies Latest reply on Feb 8, 2010 1:41 AM by screenFlavio
    SerialElement and CaptioningPugin
    screenFlavio
      Hi.
      I'd like to use the CaptioningPlugin with SerialElements.
      I modify the CaptioningSample as shown below.
      The first video start and captioning run correctly, but the second don't start.
      If I click on timebar, click and play buttons and so on, sometimes the second video and the second captioning work fine.
      can someone help me?
      Thanks.
                  private function init():void
                      mediaFactory = new MediaFactory();
                      pluginManager = new PluginManager(mediaFactory);
                      loadPlugin("org.osmf.captioning.CaptioningPluginInfo");
                      mediaPlayerWrapper.mediaPlayer.addEventListener(DisplayObjectEvent.MEDIA_SIZE_C HANGE, onMediaSizeChange);
                      mediaPlayerWrapper.mediaPlayer.addEventListener(TimeEvent.DURATION_CHANGE, onDurationChange);
                      mediaPlayerWrapper.mediaPlayer.addEventListener(TimeEvent.CURRENT_TIME_CHANGE, onCurrentTimeChange);
                      mediaPlayerWrapper.mediaPlayer.addEventListener(SeekEvent.SEEK_END, onSeekEnd);
                      mediaPlayerWrapper.mediaPlayer.addEventListener(SeekEvent.SEEK_BEGIN, onSeekBegin);
                      mediaPlayerWrapper.mediaPlayer.currentTimeUpdateInterval = DEFAULT_PROGRESS_DELAY;
      //FD modify begin
                      var serialElement:SerialElement = new SerialElement();
                      serialElement.addChild(loadMedia(new URLResource(new URL(REMOTE_PROGRESSIVE))));
                      serialElement.addChild(loadMedia(new URLResource(new FMSURL(REMOTE_STREAM))));
      //FD modify end
                      sliderDragging = false;
                      waitForSeek = false;
                      captioningEnabled = true;
      //FD modify begin
                      mediaPlayerWrapper.element = serialElement;
                      enablePlayerControls(true);
      //FD modify end
      //FD modify loadMedia: return a MediaElement
                  private function loadMedia(resource:URLResource):MediaElement
                      //var resource:URLResource = new URLResource(new FMSURL(url));
                      // Assign to the resource the metadata that indicates that it should have a Timed Text
                      // document applied (and include the URL of that document).
                      var kvFacet:KeyValueFacet = new KeyValueFacet(CaptioningPluginInfo.CAPTIONING_METADATA_NAMESPACE);
                      kvFacet.addValue(new ObjectIdentifier(CaptioningPluginInfo.CAPTIONING_METADATA_KEY_URI),
                                          CAPTION_URL);
                      resource.metadata.addFacet(kvFacet);
                      var netLoader:NetLoader = new NetLoader();
                      mediaFactory.addMediaInfo(new MediaInfo("org.osmf.video", netLoader, createVideoElement));
                      var mediaElement:MediaElement = mediaFactory.createMediaElement(resource);
                      // Listen for traits to be added, so we can adjust the UI. For example, enable the seek bar
                      // when ISeekable is added
                      mediaElement.addEventListener(MediaElementEvent.TRAIT_ADD, onTraitAdd);
                      // Listen for metadata to be added so we can add any desired event listeners on any
                      // metadata facets we care about. For example, the temporalFacet.
                      mediaElement.metadata.addEventListener(MetadataEvent.FACET_ADD, onFacetAdd);
                      // Listen for metadata to be removed so we remove an event listeners
                      mediaElement.metadata.addEventListener(MetadataEvent.FACET_REMOVE, onFacetRemove);
                      mediaElement.addEventListener(MediaErrorEvent.MEDIA_ERROR, onMediaError, false, 0, true);
                      return mediaElement;
