0 Replies Latest reply on Feb 5, 2010 10:16 AM by CoreyRLucier
    [svn:fx-trunk] 14004: Adding mxmlc and compc -size-report option which provides an XML based report roughly equivalent to the build time size report that Flash Authoring provides .
    CoreyRLucier Adobe Employee
      Revision: 14004
      Revision: 14004
      Author:   clucier@adobe.com
      Date:     2010-02-05 10:16:13 -0800 (Fri, 05 Feb 2010)
      Log Message:
      Adding mxmlc and compc -size-report option which provides an XML based report roughly equivalent to the build time size report that Flash Authoring provides.
      QE notes:  None
      Doc notes: None
      Bugs: N/A
      Reviewer: Paul
      Tests run: Checkin
      Is noteworthy for integration: None
      Modified Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilerAPI.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/Configuration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/Swc.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_en.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/linker/LinkerConfiguration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/linker/SimpleMovie.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Fcsh.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Mxmlc.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/flexbuilder/BuilderConfiguration.jav a
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Application.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Configuration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Report.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/ConfigurationConstants. java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/LinkerConfiguration.jav a
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/OEMConfiguration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/OEMReport.java
          flex/sdk/trunk/modules/swfutils/src/java/flash/swf/DebugEncoder.java
          flex/sdk/trunk/modules/swfutils/src/java/flash/swf/SwfEncoder.java
          flex/sdk/trunk/modules/swfutils/src/java/flash/swf/TagEncoder.java
          flex/sdk/trunk/modules/webtier/j2ee/servlet/src/java/flex/webtier/server/j2ee/CompileFilt er.java
          flex/sdk/trunk/modules/webtier/j2ee/servlet/src/java/flex/webtier/server/j2ee/Incremental CompileFilter.java
          flex/sdk/trunk/modules/webtier/j2ee/taglib/src/java/flex/webtier/server/j2ee/jsp/JspCompi leFilter.java
      Added Paths:
          flex/sdk/trunk/modules/swfutils/src/java/flash/swf/TagEncoderReporter.java
          flex/sdk/trunk/modules/swfutils/src/java/flash/swf/tools/SizeReport.java
