0 Replies Latest reply on Feb 5, 2010 10:42 AM by Paul Reilly
    [svn:sb-sherlock] 14005: * Global SWC cache memory reduction.
    Paul Reilly
      Revision: 14005
      Revision: 14005
      Author:   preilly@adobe.com
      Date:     2010-02-05 10:42:05 -0800 (Fri, 05 Feb 2010)
      Log Message:
      • Global SWC cache memory reduction.
      QE notes:
      Doc notes:
      Bugs: SHERLOCK-3 (SDK-24472)
      Reviewer: tharwood
      Tests run: checkintests, performance testsuite
      Is noteworthy for integration: yes, reduces global swc cache memory use
      Code-level description of changes:
        modules/compiler/src/java/flex2/tools/oem/Library.java
          Added tracing to SwcException catch blocks.
          Changed from using SwcDynamicArchive to SwcLazyReadArchive when
          compiling libraries, so that downstream compilations only pull
          into memory those things which are actually used.
        modules/compiler/src/java/flex2/compiler/media/MovieTranscoder.java
          Modified doTranscode() and it's helpers to only call
          getInputStream() if we need to read from it.
          Modified getDictionary() and getSwfSize() to close the Source
          after we are done decoding the SWF. This cause the cached bytes to
          be nulled out.
        modules/compiler/src/java/flex2/compiler/CompilerSwcContext.java
          Removed dead code.
          Modified createSource() to use new SwcScript.getABC() method.
        modules/compiler/src/java/flex2/compiler/swc/SwcLazyReadArchive.java
          Removed zipFile field and close().
          Modified load() use a local zipFile variable.
        modules/compiler/src/java/flex2/compiler/swc/SwcDynamicArchive.java
          Modified save() to null out "files".
          Modified getFiles() and getFile() to load on demand.
        modules/compiler/src/java/flex2/compiler/swc/SwcGroup.java
          Modified updateMaps() to skip an expensive assert that required
          decoding library.swf.
        modules/compiler/src/java/flex2/compiler/swc/SwcScript.java
          Replaced "DoABC doABC" field and "byte[] abc" field and updated
          accessors.
          Modified getLibrary() to no longer force a parse.
          Modified setCompilationUnit() to initialize "abc" if it hasn't
          been initialized yet.
        modules/compiler/src/java/flex2/compiler/swc/SwcLibrary.java
          Modified getSymbol() to check for null. If we are just using a
          cached SWC from an upstream compilation, def2symbol will be null,
          because it's only filled in if we do a SWF decode. For Flex based
          SWF's, def2symbol is always empty.
          Modified parse() to close library.swf after we finish decoding it,
          so the bytes can be nulled out.
        modules/compiler/src/java/flex2/compiler/swc/SwcAPI.java
          Modified exportSwc() to trace the exception before the rethrow.
          Otherwise, the trace is skipped.
        modules/compiler/src/java/flex2/compiler/swc/Swc.java
          Removed the catalogFiles field, because it's just a copy of what's
          in the archive.
          Modified read() to close catalog.xml after it's been parsed, so
          it's bytes can be nulled.
        modules/compiler/src/java/flex2/compiler/io/InMemoryFile.java
          Folded init() into the constructor, because it's only called from
          the constructor.
          Modified close() to null out the bytes.
        modules/compiler/src/java/flex2/compiler/io/VirtualZipFile.java
          Modified close() to null out the bytes instead of closing the
          zipFile.
          Refactored getInputStream() by moving the duplicate code out into
          readBytes().
          Removed the private, one line method, getEntry(), because it
          seemed silly.
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SHERLOCK-3
          http://bugs.adobe.com/jira/browse/SDK-24472
      Modified Paths:
          flex/sdk/sandbox/sherlock/modules/compiler/src/java/flex2/compiler/CompilerSwcContext.jav a
          flex/sdk/sandbox/sherlock/modules/compiler/src/java/flex2/compiler/io/InMemoryFile.java
          flex/sdk/sandbox/sherlock/modules/compiler/src/java/flex2/compiler/io/VirtualZipFile.java
          flex/sdk/sandbox/sherlock/modules/compiler/src/java/flex2/compiler/media/MovieTranscoder. java
          flex/sdk/sandbox/sherlock/modules/compiler/src/java/flex2/compiler/swc/Swc.java
          flex/sdk/sandbox/sherlock/modules/compiler/src/java/flex2/compiler/swc/SwcAPI.java
          flex/sdk/sandbox/sherlock/modules/compiler/src/java/flex2/compiler/swc/SwcCache.java
          flex/sdk/sandbox/sherlock/modules/compiler/src/java/flex2/compiler/swc/SwcDynamicArchive. java
          flex/sdk/sandbox/sherlock/modules/compiler/src/java/flex2/compiler/swc/SwcGroup.java
          flex/sdk/sandbox/sherlock/modules/compiler/src/java/flex2/compiler/swc/SwcLazyReadArchive .java
          flex/sdk/sandbox/sherlock/modules/compiler/src/java/flex2/compiler/swc/SwcLibrary.java
          flex/sdk/sandbox/sherlock/modules/compiler/src/java/flex2/compiler/swc/SwcScript.java
          flex/sdk/sandbox/sherlock/modules/compiler/src/java/flex2/tools/oem/Library.java
