0 Replies Latest reply on Feb 5, 2010 10:46 AM by jmurphy67
    [svn:fx-trunk] 14006: Localization property file update 4.0.0.14004
    jmurphy67 Level 1
      Revision: 14006
      Revision: 14006
      Author:   jimurphy@adobe.com
      Date:     2010-02-05 10:45:54 -0800 (Fri, 05 Feb 2010)
      Log Message:
      Modified Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_da.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_de.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_es.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_fi.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_fr.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_it.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_ja.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_ko.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_nb.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_nl.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_pt.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_ru.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_sv.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_zh_CN.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_zh_TW.properties
