2 Replies Latest reply on Feb 9, 2010 8:20 AM by !@#%
    Need Illustrator CS4 plug-in for export to HP PLT files
      We encountered a problem with supplying the laser plotter with .PLT files (it's the only format plotter software takes). it seems that no CS4 application can export to .PLT format, why ? is there any plug-in for Illustraotr or Photoshop that we could use ?
      Converting JPG/BMP rasters to vectorized PLT files with Corel is an option, but we want to avoid that unnecessary complication and eliminate Corel from the process.
      thanks.
        • 1. Re: Need Illustrator CS4 plug-in for export to HP PLT files
          JETalmage Level 6
          Unless I'm misunderstanding the content, I'd much rather eliminate JPG/BMP from the process. If the original is vector content in AI, export as a vector format that Draw can open (earlier version .ai, or .dxf) and then export the HPGL from Draw.
          JET
          • 2. Re: Need Illustrator CS4 plug-in for export to HP PLT files
            !@#% Level 1
            problem is that it all starts in our case with raster graphics and as you mentioned there is like 3-4 steps of converting it back and forth until COrel can finally export it to PLT - don't you think it is too much ? it's a bit ridicoulus.
            why Illustrator cannot export it to PLT ? too hard to make a conversion plugin ?
