3 Replies Latest reply on Feb 7, 2010 10:58 AM by CoreyRLucier
    BitmapImage changes in build 13875
    monkeymagiic
      Hello furry friends
      As my last post was about updating my current SDK from an early build of Flex 4 to the newer milestone one (build 13975) so is this one.
      It appears my BitmapImages within SparkSkins are not showing anymore, the assets I am importing are not dynamic and sitting in a assets folder as .PNG files. has something changed with the use of BitmapImages?
      Here is my class:
      * Generic Button Skin
      * @author    Tyrone Neill
      * @date      08/10/09
      * @see       http://www.tyroneneill.com
      <s:SparkSkin
           xmlns:fx="http://ns.adobe.com/mxml/2009"
           minWidth="70" minHeight="21"
           currentStateChanging="currentStateChangingHandler( event )"
           creationComplete="creationComplete( event )">
           <fx:Metadata>
                [ HostComponent( "spark.components.ButtonBarButton" ) ]
           </fx:Metadata>
           <fx:Script>
                <![CDATA[
                     import mx.events.FlexEvent;
                     import mx.events.StateChangeEvent;
                     import mx.utils.ObjectUtil;
                     /* = CONSTANTS                                                    = */
                      * Define the skin elements that should not be colorized.
                      * For button, the graphics are colorized but the label is not.
                      * @private
                     private static const exclusions:Array = [ "labelDisplay" ];
                     /* = OVERRIDE METHODS                                          = */
                      * Colorize Exclusions
                      * @inheritDoc
                     override public function get colorizeExclusions():Array
                          return exclusions;
                     /* = PROTECTED METHODS                                          = */
                      * Current State Changing Handler
                      * @protected
                     protected function currentStateChangingHandler( event:StateChangeEvent ):void
                          //Handle State Change Effects here
                          backgroundGradientColorTop.color = hostComponent.getStyle( 'backgroundGradientTopColor' ) as uint;
                          backgroundGradientColorBottom.color = hostComponent.getStyle( 'backgroundGradientBottomColor' ) as uint;
                      * On Creation Complete
                      * @protected
                     protected function creationComplete( evt:FlexEvent ):void
                          var dataObj:Object = hostComponent.data;
                          /* Set Data for Image and ToolTip */
                          hostComponent.toolTip = dataObj.label;
                          icon.source = dataObj.icon;
           </fx:Script>
           <!-- states -->
           <s:states>
                <s:State name="up" />
                <s:State name="upAndSelected" />
                <s:State name="over" />
                <s:State name="overAndSelected" />
                <s:State name="down" />
                <s:State name="downAndSelected" />
                <s:State name="disabled" />
                <s:State name="disabledAndSelected" />
           </s:states>
           <!-- transitions -->
           <s:transitions>
                <s:Transition fromState="up" toState="over" autoReverse="true">
                     <s:AnimateColor targets="{ [ backgroundGradientColorTop, backgroundGradientColorBottom ] }"
                                         colorFrom="{ getStyle( 'backgroundGradientTopColor' ) }"
                                         colorTo="{ getStyle( 'rollOverColor' ) }"
                                         duration="150" />
                </s:Transition>
                <s:Transition fromState="over" toState="up" autoReverse="true">
                     <s:AnimateColor targets="{ [ backgroundGradientColorTop, backgroundGradientColorBottom ] }" duration="150" />
                </s:Transition>
                <s:Transition fromState="down" toState="over" autoReverse="true">
                </s:Transition>
                <s:Transition fromState="*" toState="upAndSelected" autoReverse="true">
                                         duration="150" />
                </s:Transition>
           </s:transitions>
           <!-- background gradient -->
           <s:Rect left="2" right="2" top="2" bottom="2"
                     radiusX="{hostComponent.getStyle('cornerRadius')} "
                     radiusY="{ hostComponent.getStyle('cornerRadius') }">
                <s:fill>
                     <s:LinearGradient rotation="90" >
                          <s:GradientEntry id="backgroundGradientColorTop" ratio="0" alpha="1" />
                          <s:GradientEntry id="backgroundGradientColorBottom" ratio="1" alpha="1" />
                     </s:LinearGradient>
                </s:fill>
           </s:Rect>
           <s:BitmapImage id="icon"
                             x="{ ( this.width / 2 ) - ( icon.width / 2 ) }"
                             y="{ ( this.height / 2 ) - ( icon.height / 2 ) }"
                             includeIn="disabled, disabledAndSelected, down, downAndSelected, over, overAndSelected, up, upAndSelected" />
      </s:SparkSkin>
        • 1. Re: BitmapImage changes in build 13875
          monkeymagiic Level 1
          Looking at this more and more it does not seem to be a BitmapImage issue I am having as I see my BitmapImages are working within my itemrenderers though not the SparkSkins, any ideas?
          • 2. Re: BitmapImage changes in build 13875
            I appear to be talking to myself
            After looking up some of the posts it appears BitmapImage has changed and the you would now need to Embed the image?
            I changed the component from a Spark BitmapImage to a MX Image control:
            <s:Graphic>
                      <ns:Image id="icon" x="{ ( this.width / 2 ) - ( icon.width / 2 ) }" y="{ ( this.height / 2 ) - ( icon.height / 2 ) }"
                 </s:Graphic>
            Now what worries me about this is I would imagine the Image control is a heaview component than the humble BitmapImage? not so comfortable using this in my appz to be honest.
            Any thoughts very welcome
            Tyrone
            • 3. Re: BitmapImage changes in build 13875
              CoreyRLucier Adobe Employee
              You are correct...(you are talking to yourself).
              No, just kidding.  You are correct, BitmapImage no longer supports dynamic loading of image assets, the source for your BitmapImage must be in the form of embed data.  So as of now you should make use of an mx:Image or roll your own component.
