2 Replies Latest reply on Feb 8, 2010 10:22 AM by acath
    Thumb in scrollbar disappears when running project....
    michelmolderphotography Level 1
      Hello!
      I have a problem with the scrollbar. I edited a few parts into a horizontal scrollbar. When I my artwork (pictures) into a datalist and I run the project, everything runs well...but when I click on one of the pictures and check it as the repeated item within the datalist and I run the problem again, the thumb on my scrollbar disappeared!!!
      Only the track is visible...how is this posible?
      Can somebody help?
      Thanx in advance, michel.
        • 1. Re: Thumb in scrollbar disappears when running project....
          wadedwalker Level 3
          Without having your project I cant help you too much but I can give suggestions on things to look for. You will want to make sure all the states are set up correctly. Here is how it should all be organized:
                                          DATA LIST COMPONENT
                Repeated Item Component    +    Scroll Bar Component
          Repeated Item(s)                   Thumb + Track [+ Up(left) Arrow + Down(right) Arrow]
          You will need to check each state of those components to make sure there isnt a state where the thumb is gone. For example, the Scroll Bar component has a few states and one of them could have the thumb turned off or the Thumb Button component itself could have a state where the shape/image is turned off. Here is a list of all the states of each component:
          Data List - Normal, Disabled
          Repeated Item - Normal, Over, Selected
          Scroll Bar - Normal, Disabled, Inactive
          Thumb/Track/Arrows - Up, Over, Down, Disabled
          • 2. Re: Thumb in scrollbar disappears when running project....
            acath Level 4
            Hi Michel,
            Note that the scrollbar has 3 states: Normal, Inactive, and Disabled. Inactive is when there is not enough stuff to need scrolling - i.e. when the stuff is smaller than the window that it's in. In the inactive state, the scrollbar's thumb automatically disappears.
            -Adam
