8 Replies Latest reply on Sep 3, 2007 3:30 PM by Newsgroup_User
    Warning when adding new site
    Level 7
      I have a Web site commenced in FP2003 that I imported, using the
      FrontPage Migration Kit, into and then completed in DWMX2004. As I
      would like to reorder the site with CSS in Windows Explorer I have made
      a copy of the site with a different name.
      After going to Site | Manage Sites | New and completing the wizard a
      warning appears reading:
      The root folder you have chosen is inside the the folder for site `SGC'.
      This may cause some operations, such as synchronisation, to work
      incorrectly. Proceed anyway?
      SGC is a site in the managed list but it is not highlighted in the
      Manage Sites dialogue when selecting New. When I highlight another site
      in the list the same warning message appears also referring to the SGC site.
      How can I add the this site folder to Manage Sites without the warning
      appearing?
      Malcolm Walker
        • 1. Re: Warning when adding new site
          Level 7
          Do you have a site defined with the name SGC?
          Is the current site's root folder within the root folder for this other
          site? This warning is telling you that it is, and that when you have
          'nested' sites like this, synch operations can get out of synch.
          Murray --- ICQ 71997575
          Adobe Community Expert
          (If you *MUST* email me, don't LAUGH when you do so!)
          http://www.dreamweavermx-templates.com - Template Triage!
          http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
          http://www.dwfaq.com - DW FAQs, Tutorials & Resources
          http://www.macromedia.com/support/search/ - Macromedia (MM) Technotes
          "Malcolm Walker" <mewalker@uwclub.net> wrote in message
          news:fbfhii$k5h$1@forums.macromedia.com...
          >I have a Web site commenced in FP2003 that I imported, using the FrontPage
          >Migration Kit, into and then completed in DWMX2004. As I would like to
          >reorder the site with CSS in Windows Explorer I have made a copy of the
          > SGC is a site in the managed list but it is not highlighted in the Manage
          > Sites dialogue when selecting New. When I highlight another site in the
          > appearing?
          > Malcolm Walker
          • 2. Re: Warning when adding new site
            Level 7
            Yes
            > site?
            No
            Indeed I understand the warning and because I could not understand why
            the warning appeared is the reason for asking the question.
            The sites, SGC, MCJ(original) and MCJ(css) amongst others are in their
            own folders in a folder named Webs.
            I have now completed the Site | Manage Sites | New procedure and
            MCJ(css) appears in the Assets | Files tree as a Site not nested in SGC.
            But I am still puzzled as to the reason for the warning.
            My thanks you for your reply.
            • 3. Re: Warning when adding new site
              Level 7
              As I said, the reason for the warning is that DW is finding site "A" within
              the root folder for site "B". Can you give me the explicit path to the root
              folder for each of these sites?
              news:fbgbck$fn2$1@forums.macromedia.com...
              > Yes
              >> site?
              > No
              >>This warning is telling you that it is, and that when you have 'nested'
              > Indeed I understand the warning and because I could not understand why the
              > The sites, SGC, MCJ(original) and MCJ(css) amongst others are in their own
              > I have now completed the Site | Manage Sites | New procedure and MCJ(css)
              > appears in the Assets | Files tree as a Site not nested in SGC. But I am
              • 4. Re: Warning when adding new site
                Level 7
                Paths and actual folder names are:
                1. SGC - F:\webs\sgcdreamweaver (an import from FP2003 and not published)
                2. MCJ - F:\webs\mcjdreamweaver (an import from FP2003 and published to:
                www.mcjtraining.co.uk/)
                3. MCJ CSS - F:\mcjdwcss (A copy of mcjdreamweaver being processed for
                conversion to CSS and not published).
                SGC was the first import with the FrontPage Migration Kit. I am
                wondering if the warning is something to do with that Kit?
                • 5. Re: Warning when adding new site
                  Level 7
                  On Mon, 03 Sep 2007 00:38:58 +0100, Malcolm Walker
                  >appearing?
                  >Malcolm Walker
                  I have hundreds of sites all within a root folder and the root folder
                  is also a site (my localhost phpMyAdmin), so I see this warning
                  anytime I add a site. It has never caused a problem, though I do never
                  use sync, checkin/out or design notes.
                  • 6. Re: Warning when adding new site
                    Level 7
                    Are you sure you do not have this site defined with "webs" as the root
                    folder?
                    > SGC was the first import with the FrontPage Migration Kit. I am wondering
                    I doubt it.
                    Try this -
                    Export the definition for SGC (use the first option when you do so that the
                    FTP info is exported as well). Then, using Site Manager, REMOVE SGC's site
                    definition. Now open your other site. Do you STILL get the alert?
                    (you can always import the SGC definition after you complete this test)
                    news:fbgu7m$7km$1@forums.macromedia.com...
                    >> within the root folder for site "B". Can you give me the explicit path
                    >> to the root folder for each of these sites?
                    • 7. Re: Warning when adding new site
                      Level 7
                      > folder?
                      Yes
                      other site?
                      No
                      This No is incorrect and my answer should have been Yes as I now better
                      understand the question you asked me. All my sites are in the folder
                      F:\Webs
                      > I doubt it.
                      I agree with that doubt - now.
                      > Try this -
                      > definition.
                      Done both.
                      No
                      The problem has gone away - thank you for your guidance and with sincere
                      apologies for my earlier wrong answer.
                      Malcolm
                      • 8. Re: Warning when adding new site
                        Level 7
                        It's no problem. DW doesn't lie! 8)
                        news:fbhsk7$aif$1@forums.macromedia.com...
                        >>> published)
                        >> folder?
                        > Yes
                        > other site?
                        > No
                        > F:\Webs
                        >> I doubt it.
                        >> Try this -
                        >> the FTP info is exported as well). Then, using Site Manager, REMOVE
                        >> SGC's site
                        >> definition.
                        > Done both.
                        > No
                        > Malcolm
