6 Replies Latest reply on Feb 8, 2010 1:20 PM by andrewbt
    Problems with sound sync for HDV import (MPEG file)
    andrewbt Level 1
      I've imported a one hour tape from my Sony HDR-HC3 (HDV import), and within a few minutes the sound and video get out of sync when I play it.  I have elements v4 and also tried version 8 (trial) which was better but still a second out of sync vs 4-5 seconds for v4.  The imported files for both versions both play perfectly in Windows Media player with no sync problems.
      I'm running on Windows 7 64 bit with 4GB ram and a 4 core AMD processor which isn't struggling.  In searching the web I've seen some old workaround solutions for similar problems which involved deinstalling quicktime, installing streamclip and a quicktime alternative and then converting the files imported by Elements.  I am hoping there is a more straightforward solution within Elements which avoids having to go through this workaround.
      Has anyone had this problem and solved it?
      Andrew
