1 Reply Latest reply on Feb 8, 2010 3:42 AM by Francisc
    Best solution to connect Air and MySQL
    isabelle loyer
      Hello,
      I'm a new developper with Air solution.
      Afer a couple day of test, i'd to make a real soft.
      This soft is a little management system to little compagny.
      So I imagine two different system, one is used by people who work alone. In the same computer work MySQL database and Air. So Air application should be able to query and update MySQL .
      The second issue is to connect to MySQL database (host on the local network) with air application. Same as the one user, people must query and uptade database MySQL.
      To do that, I need a solution with security and easy to install.
      To test , I used asSQL solution but I'm not sure that it's the best!
      Thank for you help.
