9 Replies Latest reply on Mar 2, 2010 4:31 PM by JasonKingWork
    Using an armature from swc
    jonasfunkj
      Hello,
      I have build an armature in Flash CS4, and exporting it in a swc. All works fine when building the swf from the Flash IDE, but I cannot use seem to be able to use it in Flash Builder. When tracing (IKManager.numArmatures) I keep getting 0.
      I have set the armature to runtime, and remembered to listen for the FRAME_CONSTRUCTED event. Since the same code will run in Flash, and not in Flash Builder, I thought there might be known issue with this, or something I am forgetting?
      Below is a simplified version of the code:
      package {
           import fl.ik.*;
           import flash.display.*;
           import flash.events.*;
           public class Rig extends MovieClip {
                public function Rig() {
                     addEventListener(Event.FRAME_CONSTRUCTED, bodyReady);
                private function bodyReady(e:Event):void {
                     removeEventListener(Event.FRAME_CONSTRUCTED, bodyReady);
                     IKManager.trackAllArmatures(true);
                     trace(IKManager.numArmatures);
                     var tree:IKArmature=IKManager.getArmatureAt(0);
