8 Replies Latest reply on Feb 11, 2010 12:39 PM by Luis Pedro Ferreira
    Moving from local to web server (Zend config)
    Luis Pedro Ferreira
      Hi all.
      I'm trying to build a simple application using a PHP database connection which i found it really simple using the new wizard and locally every thing work 100% in just a couple of minutes, however when I upload my project to my web server something is wrong cause my application don't even start.
      Signs and symptoms:
      After uploading all the project release files and the Zend framework directory, this is what i get:
      Warning: require_once(Zend/Loader/Autoloader.php) [function.require-once]: failed to open stream: No such file or directory in /home/thezycom/public_html/PHPSQLTest/gateway.php on line27
      Fatal error: require_once() [function.require]: Failed opening required 'Zend/Loader/Autoloader.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/usr/library/ZendFramework') in/home/thezycom/public_html/PHPSQLTest/gateway.php on line 27
      The problem may be on my amf_config.ini which i have:
      For local server:
      webroot = /Users/luispedro/Localhost/PHPSQLTest
      zend_path = /user/apache/PHPFrameworks/ZendFramework
      RESULT: Everything works fine.
      For web server:
      webroot = /home/thezycom/www
      zend_path = /home/thezycom/www/PHPSQLTest/ZendFramework
      RESULT: The error above
      What i'm i doing wrong??????
