3 Replies Latest reply on Feb 9, 2010 1:40 AM by Yan Kliaver
    An error occurred creating the form (task 513, form 0). (ALC-WKS-007-040)
    Yan Kliaver Level 2
      I've created a process that get a xml as an input, read the form repository, integrate the data into the form, then the form is assigned to user as task.
      First user anotates it an it should be routed to a second user.
      The problem is that when the second user in the flow trying to open the form in Workspace the following error is appears 'An error occurred creating the form (task 513, form 0). (ALC-WKS-007-040)'.
      I'm using Document Form variable because it is important to route the form with the anotations and not only the data.
      The process and input data are attached.
      Anybody has an Idea what can be the problem?
      Thanks in advance, Yan
