1 Reply Latest reply on Feb 8, 2010 1:41 PM by msakrejda
    Asynchrounous lookup , design pattern
    UbuntuPenguin Level 4
      TL;DR How do you handle a system that can be asynchronous and synchronous depending on its state.
      Hello Everyone ,
        I have a small problem and was wondering if anyone could give me some guidance how this is solved at various places.  Here goes .
      I have some objects whose values are set by using a dictionary like object.  The dictionary works as follows.  When given the key value from the value object , it will check to see if the value has already been loaded.  If so , it will return the matching value , if not , it will query a service for the the correct value for the key.
        My question is how would you solve this , or is there already a pattern out there dealing with this in the Flex/AS3 world.
      Sincerely ,
        UP
        • 1. Re: Asynchrounous lookup , design pattern
          msakrejda Level 4
          You can always design an asynchronous API, but execute it synchronously if the data is already available. E.g.,
          [Event(name='defined', type='com.example.DefinitionEvent')]
          public class RemoteDictionary {
              private var _cached:Object;
              private var _remoteSvc:RemoteObject;
              public function RemoteDictionary() {
                  _cached = {};
                  _removeSvc = new RemoteObject('dictionaryDestination');
                  _remoteSvc.addEventListener(ResultEvent.RESULT, handleResult);
               * Define given term. When the definition is available, the 'defined' event is dispatched
              public function define(term:String):void {
                  if (term in _cached) {
                      dispatchEvent(new DefinitionEvent('defined', term, _cached[term]));
                  } else {
                      var token:AsyncToken = _remoteSvc.define(term);
                      token.term = term;
              private function handleResult(e:ResultEvent) {
                  var term:String = e.token.term;
                  _cached[term] = e.result;
                  dispatchEvent(new DefintionEvent('defined', term, e.result));
          Error handling, etc., left as an exercise for the reader.
