6 Replies Latest reply on Apr 26, 2010 4:00 PM by Wade_Zimmerman
    error! PDFFormat.aip
    eirinikefal
      please help,  illustrator CS4 can't start up!
      MISSING REQUIRED PLUGINS
      PDFFORMAT.AIP
        • 1. Re: error! PDFFormat.aip
          Reinstall? also check your permissions. PDF handling hooks into some global shared components which may not be accessible if not properly installing as administrator and running as a user with high enough privileges.
          Mylenium
          • 2. Re: error! PDFFormat.aip
            eirinikefal Level 1
            thanks for the response, but i think that the problem was on installed fonts, i 've un
            istalled all my fonts and the problem just gone!!
            but when i tried to install some more fonts now, i get the error:  an error has occurred!
            any idea!
            i have installes and reistall, i have done format, i have installes a full adobe suite, but i always have problems!
            no  that, i can't install greek fonts!
            thanks eirini
            • 3. Re: error! PDFFormat.aip
              crisllob Level 1
              por favor me podeis explicar como lo solucionasteis... yo me lo he descargado de adobe para los t30 dias de prueba
              y me dice error pluggins pdfformat.aip
              y no se que hacer
              • 4. Re: error! PDFFormat.aip
                Wade_Zimmerman Level 6
                Como se indica en este hilo, el problema parece estar con las fuentes que no son compatibles con Illustrator o fuentes son corruptos.
                La autorización así que usted podría tener cualquiera de fuentes corruptas en el sistema o las fuentes libres tal vez algunos no tan buenos.
                Qué hacer quite las fuentes que podrían estar causando un problema, sobre todo las fuentes libres. a continuación, intente iniciar Illustrator.
                Si es necesario volver a instalar el Illustrator.
                In  Wade English
                As indicated in this thread the problem seems to be with fonts that are not compatible with Illustrator or the fonts are corrupt.   Ok so you might have either corrupt fonts on your system or perhaps some not so good free fonts.  What to do remove the fonts that might be causing such a problem, especially the free fonts. then try to launch Illustrator.  If need be re install Illustrator.
                The user was saying they have essentially the same problem with the 30 day trial.
                Usted debe saber que el CS 5 será lanzado pronto por lo que será mejor esperar al nuevo juicio que probablemente estará disponible unas semanas después de la fecha de lanzamiento al por menor.
                You should know that CS 5 is coming out soon so you will be better off waiting for the new trial which will probably be available a few weeks after the retail release date.
                • 5. Re: error! PDFFormat.aip
                  crisllob Level 1
                  como puedo saber que fuentes no son complatibles con illustrator cs4 para eliinarlas?
                  • 6. Re: error! PDFFormat.aip
                    crisllob wrote:
                    eliinarlas?
                    Esta palabra dos no se traducía bien puede escribir de otra manera? Por favor!
