0 Replies Latest reply on Feb 8, 2010 2:59 PM by kevinklin
    [svn:fx-trunk] 14047: Modifying framework projects to not depend on the FLEX_SDK linked resource .
    kevinklin Adobe Employee
      Revision: 14047
      Revision: 14047
      Author:   klin@adobe.com
      Date:     2010-02-08 14:58:51 -0800 (Mon, 08 Feb 2010)
      Log Message:
      Modifying framework projects to not depend on the FLEX_SDK linked resource. Instead, we use the $ token (relative path to frameworks/) to point directly to the required swcs in the libs folder. This greatly simplifies the files, since there is now no need to exclude swcs from the SDK.
      Also, modified the projects such that the spark and framework projects may be imported together to FB without any other projects by having them depend on the swcs in the libs folder rather than the projects. However, other projects that depend on spark and framework will depend on the projects still. Thus, you must import spark and framework projects before importing the others.
      A developer working on the textlayout and osmf projects will have to replace the swcs on the build path in the spark/framework projects with their respective projects.
      No code changes.
      QE notes: N/A
      Doc notes: N/A
      Bugs: None
      Reviewer: Pete
      Tests run: checkintests
      Is noteworthy for integration: No
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/airframework/.actionScriptProperties
          flex/sdk/trunk/frameworks/projects/airframework/.flexLibProperties
          flex/sdk/trunk/frameworks/projects/airspark/.actionScriptProperties
          flex/sdk/trunk/frameworks/projects/airspark/.flexLibProperties
          flex/sdk/trunk/frameworks/projects/flex/.actionScriptProperties
          flex/sdk/trunk/frameworks/projects/flex/.flexLibProperties
          flex/sdk/trunk/frameworks/projects/framework/.actionScriptProperties
          flex/sdk/trunk/frameworks/projects/framework/.flexLibProperties
          flex/sdk/trunk/frameworks/projects/osmf/.actionScriptProperties
          flex/sdk/trunk/frameworks/projects/osmf/.flexLibProperties
          flex/sdk/trunk/frameworks/projects/rpc/.actionScriptProperties
          flex/sdk/trunk/frameworks/projects/rpc/.flexLibProperties
          flex/sdk/trunk/frameworks/projects/spark/.actionScriptProperties
          flex/sdk/trunk/frameworks/projects/spark/.flexLibProperties
          flex/sdk/trunk/frameworks/projects/sparkskins/.actionScriptProperties
          flex/sdk/trunk/frameworks/projects/sparkskins/.flexLibProperties
          flex/sdk/trunk/frameworks/projects/textLayout/.actionScriptProperties
          flex/sdk/trunk/frameworks/projects/textLayout/.flexLibProperties
          flex/sdk/trunk/frameworks/projects/wireframe/.actionScriptProperties
          flex/sdk/trunk/frameworks/projects/wireframe/.flexLibProperties
